Fillet won't fillet at half radius
All  1-3  4-8
4584.4 In reply to 4584.2
Michael
Confirmed! You are correct :)
Wow, I didn't realise there was a difference.
4584.5 In reply to 4584.4
Hi NightCabbage,
There isn't supposed to be for a case like that, that's definitely a bug there. I've added it to my list, it should probably not be too hard to fix up.
The click-focused nature of it is so that you can control which of the 2 possible fillets is created for cases like this:
You'll get different results there depending on which side of the intersection point you clicked on when selecting the horizontal line with a click.
When doing a window select it's supposed to automatically pick one (preferring to keep the longer piece if there are different sizes involved if I remember right), and it's not supposed to make any difference when both curves come to a single shared endpoint instead of meeting in a T like above or an X, but something in that part seems to be where the bug is at.
4584.6 In reply to 4584.1
Hi NightCabbage, also you may already know this but just in case - you don't actually need to do a separate on the rectangle first, you can select the whole still joined rectangle and then do a Fillet and it will prompt you to pick which corners you want to fillet.
4584.7
lol This all sounds awesome :)
I think the problem is that, to my knowledge, these features aren't documented?
I bet there are ton of features in MoI that would make my life much easier - but I just don't know they exist! :D
4584.8 In reply to 4584.7
Hi NightCabbage,
Being able to fillet corners of a single joined curve is documented in the help file under Fillet:
http://moi3d.com/2.0/docs/moi_command_reference7.htm#fillet
"Selecting a single curve that has corners in it (for example, a rectangle curve) will allow filleting of some or all of those corners."
Also one of the example images shows that kind of filleting with selecting corner vertices...
Show messages: All  1-3  4-8
