Majik Tutorial: Audio Speaker
 1-2  3-22  23-42  43-59
4561.23 In reply to 4561.22
Yeah.. I looked at that silly CPU/MEM "Gadget" Windows 7 has, it was at around 25%.
And there may be something else not set right. The vid driver temporarily crashed twice today. Once when only Adobe reader was running.
But me and my brother are still in the "let's see if this baby really works" phase of this new work PC.
But man! Does it feel good to get a MoI model rendered. :-)
4561.24 In reply to 4561.23
Hi Mike, one thing to keep in mind is that MoI is a 32-bit program, so it will max out at something like around 3.6 GB of memory usage, not when all your full 64-bit system memory is exhaused.
So to monitor MoI for running out of memory, if you're on a high memory 64-bit OS you'll really need to monitor MoI.exe in the process list and not just your overall system memory consumption. If you're on a 32-bit OS or on 64-bit with more like 4GB of memory then you could watch overall system memory.
When you have a particularly high level of geometry like you're doing here you will probably need to pay some extra attention to some things like this which you don't need to worry about so much with a more regular kind of model.
You also may get some better results for high complexity models if you reduce the display mesh density to be coarser - that can help to reduce memory consumption by quite a bit.
Some details for that in this previous post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4196.2
The settings for that are under Options > View > Meshing parameters - try setting "Mesh angle" to 25 degrees and uncheck "Add detail to inflections". That may reduce memory load a fair amount.
4561.25 In reply to 4561.23
Hi Mike,
You might make sure it's not getting overheated - is your system possibly overclocked?
Also it's probably a good idea to go directly to your video card manufacturer's web site and download the latest driver they have available from there to see if that helps.
4561.26 In reply to 4561.25
Thanks for that advice... I was wondering about the limitations being a 32 bit app.
We were thinking some of the same things about the video.
I had a tech put me on a different login with admin priv. due to requirements to get my M$ Outlook connected among other things.
An error log my brother was looking at eluded to the fact that something was denied some type of privileges when MoI crashed.
I plan on uninstalling and re-installing the INVIDIA driver in the morning to rule that out.
If it was a hardware problem the vid card blackouts (2 of them) would have happened when I was taxing my system... hard to tell at this stage.
But yes... that model is a stresser for MoI under any circumstances.
MAJIKMIKE -
I really like the render - nice dramatic lighting. Again, a fantastic model and I'm trying it out right now in KeyShot (still can't get the grill exported out of MoI due to memory limit).
Do you mind if I post a KeyShot version later tonight?
Ed
4561.28 In reply to 4561.27
Thanks Ed!
Yes, go ahead - that's why I posted it. Have at it!
Ed, try this out: http://www.mediafire.com/?3tlre2zc6y1qh (test 1.zip)
It is the .obj that worked for the wire mesh. Can't guarantee it, but give it a try.
4561.29 In reply to 4561.28
Hi Majik,
Just a mention on the original surface you had import issues with, that is a "joined surface" and not a solid, so it may have had something to do with that. Although you did get it going with quads and tris, so it is just information/speculation.
4561.30 In reply to 4561.29
Hi Burr that kind of looking thing where triangles seem to be leaking out of an n-gon outline usually means that something went wrong with a process of converting n-gons into triangles.
In order to convert an n-gon into triangles, one edge of the n-gon will be connected to a point somewhere else on the n-gon. If it's not handled carefully then the connection to that other point could cross over the outside area of the n-gon if it's a complex concave type shape.
That's something that can tend to happen pretty easily in n-gon triangulation functions, it's not all that easy to make a really robust triangulator.
If the rendering program that you are exporting to has those kinds of problems in handling complex n-gons, then you'll need to use the "Export: Quads & Triangles" option to do the triangulation in MoI instead of relying on the rendering program to do it.
Majik -
Here's your model rendered in KeyShot. Thanks for sharing!
4561.32
hi Majik
i exported your mesh without problems, (i don't understand exactly..you got this mesh in obj or not??? )if needs take a look below
for Rich
sorry for misunderstandings:MY APOLOGIZES.This is a peaceful forum,this also is main reason when i decided to post some stuff
I respect you and i told you
in dutch without dubts:Mijn excuses
EDITED: 25 Mar 2021 by M-DYNAMICS
4561.33 In reply to 4561.32
@m-dynamics
No problem and thanks for the kind words. :-)
Peace,
Rich_Art. ;-)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R13 Studio + VrayForC4D + UVLayout Pro + 3DCoat
4561.34
Thanks Mike!!
Very good tutorial, and nice result!!
Man that's a lot of screen captures!!!! :)
4561.35
Hi all! It is impossible to make. Please explain as?
-Riko
4561.36 In reply to 4561.31
Oooh niiiice.. that's clean lookin' Ed! :-)
KeyShot is good with metals.
klickoff,
http://moi3d.com/forum/index.php?webtag=MOI&msg=4549.1
The reference circle has to have the same number and spacing of web control points.
If you revolve a flat curve - even with points making up that curve - MoI will make a planar surface with four points at the corners.
You need to lift one of the control points in Z a little before revolving it, so that you end up with a reference circle with a control web.
Therefore, Flow will match structure to structure.
See below:
You can see that the structure for the reference circle is like unto the target shape - see the web control structure.
Hope this helped.
4561.37 In reply to 4561.36
Thanks Magic (MAJIKMIKE) !!!. I have received the nice result.
-Riko
4561.38
Great Job on the speaker...render in Carrara
4561.39
Grendel - that is one beautiful render! Good job!
I like the old English type "MoI" on the cone dome.
Thanks!
4561.40
Hello,
Quick render done with Thearender 1.1. Nice tut and model Majik.
M Speaker
EDITED: 3 Feb by OSTEXO
4561.41
NICE render QSTexo! You can even see the glints in the mesh.
BTW, what render mode did you use, and what was the time?
The more I look at different renderings of the mesh, the more it's complexity freaks me out a little... that was a LOT of wire objects!
I really appreciate the different styles and approaches when it comes to everyone's renderings.
NOTE to all::: Feel free to try your hand at rendering the mesh and speaker if your wish and in a few days, I'll post them in another entry in the gallery.
4561.42
Hello,
TR1 Unbiased, about 20 minutes cooking time, but I'm not sure when it cleaned up since I was working on other things. Thearender continues to impress me, the speed increase is noticeable in 1.1. You have a good idea how things look within the first minute of the unbiased render, and even faster with the interactive render in the viewport. No post processing was done to the image, that is straight from Thea.
Show messages:  1-2  3-22  23-42  43-59
