BaseBall
All  1-7  8-10
Can you repost the 7z file as a zip file format ?
Edit:
I have uploaded the last alpha version of 7z and seems now all is working fine! ;)
But for the future save your files in Zip format, it's better for most users! ;)
Ps What is the best numbers of points by default ? You give 200 but...
EDITED: 7 Jan 2014 by PILOU
PS No possibility to have a "strip" resizable ?
4553.10 In reply to 4553.9
What is the "best" number of points?
200 points gives a quick result, which looks OK if not zoomed in on.
Interpcurve factory is currently used. Curve factory could be substituted.
10,000 points might be slightly smoother, but takes time, and memory resources are limited at some number of points.
Tried 10,000 points, with rebuild of .00001, which works OK...
The "basketball" script has controllable width, but is shaped differently.
The "basketball" script with aFactor of 17.2, and radius of 1.4607405 resembles the baseball.
EDITED: 22 Aug 2014 by BEMFARMER
Show messages: All  1-7  8-10
