Log Aesthetic Space Curves
All  1-4  5-15
4543.5 In reply to 4543.4
Thank you Michael.
I'll try some debugging.
Crashing only occured when trying to see more of the infinite curve...
After correcting a few simple bugs, (failing to name variables properly),
now have a parametric 2D Logarithmic Spiral.
Ran a simple Sweep with two circles.
The script is of the same pattern as other simple parametric scripts, based upon the ToroidalHelix Script.
Just plug in the proper simple parametric equations.
To use the script, just unzip it and copy the two files to the MoI3Beta command subdirectory. (Same subdirectory as MoI2. (Currently))
Then set up shortcut key under MoI3 options icon. (Can also do shortcut key under MoI2 options icon, for MoI2 usage.)
It might be nice to distribute the points more uniformly, not cluster them in the middle.
EDITED: 24 Sep 2011 by BEMFARMER
4543.7
Bemfarmer,
When are you going to cut some of these cool models/scripts? I hope you haven't been neglecting your Hybrid... :)
Bob K
4543.8 In reply to 4543.7
Deleted.
Anyway, MoI is the greatest program.
EDITED: 23 Oct 2011 by BEMFARMER
4543.9
Thanks bemfarmer, for another useful script!!!
Made a 2 turn red logarithmic spiral, then did tab Rebuild.
Rebuild really cleaned up and reduced the point count.
Then did an overlaying 3 turn blue logarithmic spiral.
The two spirals are very nearly the same.
Zooming in shows a slight difference in the two curves.
Made some 2D marbles.
EDITED: 27 Mar 2012 by BEMFARMER
Hypnotic!
A quick "yin & yang", 2D log spiral, using the superb, and incredibly easy to use MoI program!
EDITED: 9 Aug 2013 by BEMFARMER
4543.14 In reply to 4543.11
WONDERFUL! Great use of Moi 2d toolset.
4543.15
The Lollipop Guild would be proud! :-)
Awesome creation!
Show messages: All  1-4  5-15
