V2: Sweep or network?
4541.1
Hello,
from the curves in the attached project I want to create a sweep by the body.
Like on the picture attached picture.
But I do not get out!
Sweep is correct?
Or should I use network?
Size: 22.1 KB, Downloaded: 95 times, Dimensions: 181x174px
Take habit to put the object over the center of the grid on the 3 views ;)
Here it's floating in the free deepth space ;)
Network loves 4 sides surfaces
and sweep loves no deconnected profils
So join some segments between them and that will be good ;)
EDITED: 24 Sep 2011 by PILOU
4541.3
This would be a good case for a skinning tool of some type that would form a surface from multiple edges...
But it may be wise to break this shape down into manageable sections where you only have four sides to work from.
Tangent surface edges might be a problem by doing it this way, but there may be workarounds.
4541.4 In reply to 4541.1
Hi Sirius - you've basically got too many things trying to happen all simultaneously to make a good surface out of that.
You've got a 5-sided boundary, you've got a lower piece that kind of protrudes suddenly, and on top of that you have some sharp corners in the middle of some shapes. Each of these things adds a kind of complexity to the layout.
You're generally better off trying to build a single surface with sweep or network out of a single smooth piece rather than trying to force so many different kinds of variations into a single surface creation command.
When you have something like a piece that kind of suddenly protrudes from another one, it's generally better to build that as a separate object and then fillet them together.
Otherwise to actually build a network or sweep directly would require adding in some more in between curves along the lines of what Mike is showing above - another possibility is attached here.
But I'd probably try more to build it more as separate pieces and either fillet or blend them together rather than trying to build that whole thing in one sweep.
4541.5 In reply to 4541.4
Hello,
I had already suspects.
Thank you for the detailed answers
Bye
Sirius
