Hi Jean-Paul, maybe something along these lines - starting with some curves arranged liek this:
The outside ring gets extruded to make a solid, then use Boolean difference to cut that solid by the other 2 inner pieces, so you've got 3 solids like so:
Put a big fillet on the outside edge:
A little bit less fillet radius on the inside parts:
Maybe use the G2 Blend fillet shape rather than a circular fillet cross-section, and another possibility might be to slice off the front face with a slightly rounded surface to make it look less totally flat in front, see for example this previous post for an example of that kind of thing:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4296.5
It's also possible that you may want to make some kind of tubular sweep for the outermost one instead of a filleted block but maybe the inside pieces would be good to do with fillets on extruded pieces.
