Pillow Script, request for method to put end points on factory curves.
All  1-3  4-10
4512.4 In reply to 4512.3
Hi Brian, let me know if it still does not make sense and I will take a look into your script to give you some more specific help.
For stuff like how for( ) loops work in the JavaScript language, there is a pretty good resource here:
http://www.w3schools.com/js/default.asp
That's a bunch of tutorials and reference materials for doing web-page scripting, and that's the same script language that is used by MoI. There are a bunch of tutorials there and some reference materials for how different statements in the language work.
After many trials and tribulations, finally realized that the factory declaration was before the for loop.
Moved the factory declaration down 4 lines, inside the first for loop, and the script works just fine.
It was a fairly good learning experience though.
The script is set to just create the top half of the pillow. (Loft, and Mirror the bottom.)
The Height and Length of the pillow can be adjusted.
Used "interpcurve" curve type, which I believe is Through the points, versus "curve" type.
Hopefully there are not too many bugs.
Attached new Pillow3Web script.
Next up is escargot.
EDITED: 9 Aug 2013 by BEMFARMER
4512.6 In reply to 4512.5
Yup, that's correct.
Thank You.
EDITED: 24 Sep 2015 by PILOU
4512.9 In reply to 4512.8
How about "mark curve start"
Flip
"mark curve start"
4512.10 In reply to 4512.8
I'll have to look at this again, for the points.
Amazingly, its been 4 years!
Some learning has occurred meanwhile :-)
Show messages: All  1-3  4-10
