Background Image
4506.1
Good Afternoon, all...
I have gone through the search and tutorial series to find specifically what I need to do to get a background image loaded that I can trace above, to create a series of profiles to be used for sweeps.
I am actually using a woodworking profiler to capture the profile and transferring the profile to graph paper.
Can someone please describe what I need to do to display these profiles in the background, to include the proper file format needed, loading the image and following the underlying profiles. I've tried to follow the description of "images", but, not clear to me without examples. The Ferrari example is what I need to be able to duplicate, but, no description of how it got to the background and the file format used.
Unless there is a better way, I intend to scan the image and save it in Photoshop and write it out in some file format compatible with MOI's background capability.
4506.2
Hi Bob,
In view panel, click on image...
In the dialog press Add...
Select the file from the open file popup.
Most common image formats will work.
In the viewport click to specify the corners of the image.
Marc
4506.3 In reply to 4506.2
Thank You, Marc...that is precisely what I needed. I appreciate your taking the time to respond.
Regards...Bob
4506.4 In reply to 4506.1
Hi Bob, also if you need to place multiple images to align with one another see these previous posts for some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2501.14
http://moi3d.com/forum/index.php?webtag=MOI&msg=2501.15
http://moi3d.com/forum/index.php?webtag=MOI&msg=1982.6
