Control Points
All  1-4  5-8
4501.5 In reply to 4501.4
Hi Michael
Just chose red at random for the example as it helped illustrate my point! I agree that red is definitely not suitable, and something subtle would fit in with the whole MoI3D default colour scheme. I actually find the default colours relaxing on the eyes when using it for long periods. As for the colour to use, it could even be as simple as the end of curve control points could be black, not white?
For my original request, I was only looking for the ends of the full curve, i.e. a control point that was not intermediate in a curve or as part of joined segments. Though thinking about it I can see the ocassional benefit of segment ends being highlighted as well, perhaps in grey, i.e. a midway status between a end of full curve (black), and a partway control point (white).
Having it as an option in an extended properties dialog (perhaps under the Options/View panel?), would be a perfect solution for me.
Like so many of the others on this forum who have said it before, having the chance to put issues like this to you (even if they aren't possible or acceptable), really makes MoI3D stand out from all the other packages I've used. I really appreciate the effort you put into this, and use MoI3D as part of my hobby time, because it is so fun and easy to use!
Andrew
4501.6 In reply to 4501.5
Hi Andrew, in general I kind of dislike tagging things with too many special colors - for the most part colors are kind of reserved for you to use to organize your model using styles, and having too many various kinds of colors for other purposes can kind of be cluttering. It also tends to be kind of hard to make colors have really specific meanings to them other than a few cases like red = danger.
I was kind of thinking more about having them marked more by a difference in shape, maybe something like an extra ring around the outside of the the regular point.
The problem here is that curve points are not necessarily outlined in black - they will have the color of the style assigned to the curve. So for example if you select a curve and assign it style = Blue, and then turn on its control points currently, you should see the points actually have a blue outline then.
You mean an option for making every curve in the whole model have its ends marked that way?
The way I was thinking was more that you be able to turn it on or off for just some particular curves that you have selected, probably the access point would be a button on the properties panel that shows up when you have selected some objects, something like this:
The idea there would be that pushing that "Properties" button would pull up an extended object properties dialog where I would have plenty of room to put in a lot of diagnostic and detailed information controls, something for turning on additional markers for endpoints could fit in well there.
Thanks very much Andrew, I'm really glad that you are having fun with MoI!
4501.7 In reply to 4501.6
I second that 100%.
Peace,
Rich_Art. ;)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R12 Studio + VrayForC4D + UVLayout Pro + 3DCoat
4501.8 In reply to 4501.6
Hi Michael
Understand fully now about the whole colour issue. Yes I can see that shapes would be better.
I'd be very happy with clicking on a properties button as you illustrated. It would also keep things simpler in the Options box, something I remember appreciating when first using the V1 Beta!.
Thanks again
Andrew
Show messages: All  1-4  5-8
