Nurbs solids
All  1-3  4-6
45.4 In reply to 45.3
That would work if you trimmed the sphere with a line, since the line will project to a planar cut in the sphere.
But if you draw a wiggly curve as the cutting object, the resulting cut will not be a flat planar curve, that's when you'll have to do those different steps.
Quick note - Planar also works on surfaces/solids too, in addition to curves. If there are any open edges of a solid that form a planar loop, it will create a surface there and join it in automatically.
For example - draw a circle, extrude it with cap turned off - now you can select the extrusion and hit "Planar" to seal off the caps.
45.5 In reply to 45.4
I had trimmed my sphere by a Plan :)
As show my image above :)
EDITED: 4 Sep 2006 by PILOU
45.6 In reply to 45.5
Your mini tut above works like a charm :)
Show messages: All  1-3  4-6
