Change between 2D and 3D
All  1-7  8-10
4497.8
I said shift cause it was the first thing that came to my mind and... I agree with you, the view is not the only thing that has to be aligned. I like your idea of pressing a key while rotating. If that can be done it will be very welcome!
4497.9 In reply to 4497.7
one thing that I would find usefull, is to be able select or choose any of the top, front or side "cplane" while in the 3D viewport. Of course this is without having to create a cplane manually each time. Maybe some kind of script assign to a shortcut key might do it if it doesn't already exist.
Felix
4497.10 In reply to 4497.9
Hi Felix, yeah it is possible to set up some scripts on keyboard shortcuts that will flip the cplane to the Front or Right one while you are in the 3D viewport.
Check out this message for the scripts to use:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2008.2
Also a related thing is a script to set the cplane to be aligned with the current angled view direction of the 3D viewport's camera:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2599.4
Show messages: All  1-7  8-10
