Aircraft Wing Root Fillet
 1-7  8-27  28-47  48-51
4488.8 In reply to 4488.6
Hi Burr - re: n-sided patch - that hole you've got in the blue one I don't think is feasible to fill with n-sided patch since it's got that pointy part that's kind of sticking up 90 degrees away from the side loop part. That's kind of too much variation within a single patch to fit very well.
N-Sided patch basically starts with a plane and then squishes points on that plane up or down until it is deformed to fit the outline. But with that much variation the outline there will be difficult to fit to.
I don't think you can put a smooth single surface in that spot - I think it needs to have a ridge down the middle of it to match with the sharp point on the other side.
Something more like put a line down the middle of it and then patch each side separately, see attachment.
4488.9 In reply to 4488.8
Hi Burr, so I guess what you would really want there would be for the fillets to just continue and meet each other in a sharp crease instead of it trying to put in a corner patch in that spot. I don't think there is any way to get the fillter to do that, but actually if you look at each fillet piece, they're actually trimmed back parts of a larger fillet like this:
Unfortunately they don't quite extend far enough to totally finish crossing over each other, so it doesn't quite work but you can see in the attached 3DM file how that could work if they just extended a bit more.
I think what you would want here would be a way to get a maximally extended fillet - that could be possible for me to add as an option on surface/surface filleting - that's the variation of filleting where you work between just 2 individual surfaces instead of picking edges.
4488.10 In reply to 4488.8
""""""""I don't think you can put a smooth single surface in that spot - I think it needs to have a ridge down the middle of it to match with the sharp point on the other side.
Something more like put a line down the middle of it and then patch each side separately, see attachment"""""""""
Yes, i was working that, but couldnt get the surface to maintain tangency/curvature against the other ones (The existing blend and the body surfaces).. I was trying various sweeps and different ways to draw that "spine", but couldnt get a smooth result... I was wondering if ther was a Rhino command that would do this in this situation.
For instance, running a blend of 10 on these 2 curves here, gives a great result, but you can see it deviate away from the body, so thats not a good command for it.. Maybe when MoI gets a multi edge blend then these would be possible?
4488.11 In reply to 4488.10
Hi Burr,
Rhino's Patch command should do that, on the version that I posted that has a dividing line running down the middle and the long edge split into 2 pieces. You would run it in 2 separate passes though, select 3 inputs at a time - 2 edges and the centerline curve.
4488.12 In reply to 4488.10
Hi Burr,
That wouldn't really apply for this situation - it looks like you want to pin down the side parts of the blend. Multi-edge blend means being able to pick a longer chain of edges for each side of the blend, not really about doing something for the other ends of the generated blend surface.
4488.13 In reply to 4488.12
OIC regarding the patch.. :o
Thanks for the help! Patch worked great!
EDITED: 6 Sep 2011 by BURRMAN
4488.14 In reply to 4488.7
Hello prop-design !
Thank you for your encouraging words. Wing root fillets do tend to be among the most complex surfaces on any aircraft. So I new from the start that was not likely to be easy.
But this sort of thing is the reason I invested in MOI - I certainly couldn't do it in Alibre' - which is very good in other ways.
I'll keep trying.
John
4488.15 In reply to 4488.9
Hello Michael,
It looks to me as though you've cracked it !
I am afraid that I am going to expose my ignorance here - did you intersect the wing and fuselage surfaces and then apply various fillets ?
I confess that I am struggling to understand how you achieved your result.
The "sliver" you pointed out was an attempt by me to fill the the original gap I discovered, between the upper and lower wing surfaces. I am still puzzled as to how I created the gap in the first place.
Is there any sort of "history" file created within your software that would allow me to review previous actions ?
John
4488.16 In reply to 4488.15
Hi John,
> various fillets ?
That's actually Burr's model that he attached above here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4488.6
It looks like he cleaned up that little slivery part and got the wing and body joined together as one connected piece and then used Fillet to produce the rounding - here it looks like he used the "Shape: G2 blend" option for generating the fillet, which puts a kind of more semi-organic shaped blend surface for the generated fillet rather than one that has an exact circular cross section like a regular fillet. That option can be good when you want to have a somewhat more seamless looking connection between 2 pieces.
The fillet seems to have worked well for the leading edge area, but the small area on the trailing edge side needs some rework since the filleter tries to build a corner patch there that is kind of squished up so that part needs to be deleted and something else filled in there.
But it's pretty important to get the base surfaces cleaned up with that little slivery piece removed - having a little slivery bit like that will tend to get in the way of a lot of kinds of techniques of trying to make a good connection.
4488.17 In reply to 4488.15
Hi John,
No, there's nothing yet for reviewing a log of all actions that were used to build a particular model. That is something that I want to work on in the future.
If you are still in the same modeling session you can try to use Undo to rewind things though.
4488.18 In reply to 4488.17
This short video shows what I did to your model...I also added a slightly different method to the leading edge of the wing, to get what "I" thought was a better surface.. But not needed.. Basically just showing the making of 2 solids that will union properly for a fillet.. An n-sided patch is need to finish off the trailing edge.. I cant tell you how many times I need that command!!! :o (still havnt purchased Rhino)
4488.19 In reply to 4488.18
Sound is very good this time! ;)
Cool tutorial!
Ps What is the code for put the Youtube video inside the forum?
4488.20 In reply to 4488.18
Hello BurrMan !
I was just about to post a message asking why I could not unzip your original fillet model - when I noticed that you had posted your video.
To say that I am blown-away by your video response is an understatement !
I shall watch it repeatedly until I fully understand all of the contents.
Incidentally, I had come to the conclusion that I had chosen the wrong method of creating the wing in the first place. But hey-ho, one learns by mistakes !
Many thanks again.
John
4488.21 In reply to 4488.16
Good Morning Michael, (Well it is here in wet and windy Hertfordshire)
This has been a very useful learning session - particularly the "Rebuild" command.
I am now an official fan of both MOI an BurrMan !
John
4488.22 In reply to 4488.18
Burr:
When is your training book with video DVD for MOI coming out :-P.
4488.23 In reply to 4488.18
Cool video Burr! believe it or not I didn't know you could pick a whole open ended joined surface and just hit 'planar' to instantly cap the ends and turn into to a solid, I used to pick the edges, cap the ends, then join, who knew! We learn something new every day :)
Thanks!
BTW you could try a tiny fillet on that trailing edge before the union and main fillet that should get rid of that fillet abnormality.
EDITED: 7 Sep 2011 by DANTAS
4488.24 In reply to 4488.23
"... I didn't know you could pick a whole open ended joined surface and just hit 'planar' to instantly cap the ends and turn into to a solid, I used to pick the edges, cap the ends, then join"
Me too. Guess I better read the manual :)
Ed
4488.25
Burr makes a darn good tutorial - Good work Burr!
4488.26 In reply to 4488.25
Cool video Burr!
It's always interesting to see how others work.
I also learned about the planar capping feature and that you can crank up the blend value past the slider max.
Marc
4488.27 In reply to 4488.19
Thanks guy's!!!!
Frenchy: """"""""""What is the code for put the Youtube video inside the forum?""""""""""
It's the embed button, but you have to go just below that and put a check mark in "use old embed code", then copy and paste.. The forum will strip out everything but the embed part...
So it looks like this part of a flash embed tag:
embed src="http://www.youtube.com/v/Yp1NXKwyf6I?version=3&hl=en_US&rel=0" type="application/x-shockwave-flash" width="560" height="345" allowscriptaccess="always" allowfullscreen="true"></embed
(i removed the begining and ending brackets so it shows in the forum)
Show messages:  1-7  8-27  28-47  48-51
