Flow Test
 1-8  9-28  29-48  49-68  69-79
4487.9 In reply to 4487.2
Thanks Pilou!
Michael Gibson wrote:
"For applying them on to a sphere it may be a good idea to leave a little bit of margin area between your objects and the top and bottom edges of the plane, because those regions are compressing down to just a single point on the sphere and probably creating some degenerate geometry there. Probably it's ok for stuff like rendering though."
I did leave a small space on the top and right side of the flat plane and it seemed to work OK but I could see how it could cause problems with the top/bottom of the target mapped sphere.
This is a dome friends and I made before the days of 3D.;)
PS. - we didn't kill the moose, they were there when we got there.
EDITED: 7 Sep 2011 by SBEECH
Size: 936.3 KB, Downloaded: 181 times, Dimensions: 800x556px
4487.10
From a few simple shapes & different warps...
4487.11 In reply to 4487.10
Nice examples. :-)
Peace,
Rich_Art. ;-)
| C4DLounge.eu | Our Dutch/Belgium C4D forum. Cinema4D R12 Studio + VrayForC4D + UVLayout Pro + 3DCoat
4487.12
Thanks Rich, quick contour and occlusion render from Modo.
Design!
4487.14 In reply to 4487.12
Cool look with the edge contours included!
4487.15
Thanks Guys! Yes, I like the illustrated look of contours. :)
Last test with this one, example of using flow on the results of a flow....
EDITED: 8 Dec 2013 by SBEECH
Cool PDF 3D!
Is that a theater?
4487.17
Thanks Pilou!
No just a random set of shapes.
4487.18
Flow to a Toroidal Knot using bemfarmers' excellent script. Thanks bemfarmer!
Rendered in Modo:
EDITED: 2 May 2023 by SBEECH
4487.19 In reply to 4487.18
Cool pattern! Just imagine trying to model that one directly in place in 3D...
Cool image!
Like Topmod Model! http://code.google.com/p/topmod/
It's a Moi script? have you the link?
4487.21 In reply to 4487.20
Hi Pilou - Bemfarmer's toroidal knot plug-in here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4430.1
Many thanks!
Damned, this was released in August when I was not here!
So missed!
Ps I have made some publicity around the world of your previous images in some forum 3D :)
(and of course flow Moi function ;)
4487.24 In reply to 4487.18
Holy cats Danperk!! That thing is incredible!
4487.25
Thanks Mike, not skill, just trickery. ;)
4487.26 In reply to 4487.21
Great Flow example!
I've got to try one. I do have Alibre and Keyshot 2, but it only takes .bip format.
The toroidal knot script is about 99% copied from Michaels Toroidal Helix script, with I think, one added parameter.
@danperk
Does the rectangular pattern are separated objects or just one object boolean union?
from my tests both is working
but maybe one is best than some?
EDITED: 22 Sep 2011 by PILOU
4487.28 In reply to 4487.27
They were separated objects. As you say, both would work but it's easier to modify the pattern as separated items.
I use the CurveLengthV2 script to copy/paste the width/height from destination object to rectangular base object.
From Petr's MoI page:
http://kyticka.webzdarma.cz/3d/moi/
http://plugmoi.voila.net/index.htm
PS. If you wanted to manufacture this object, it would be better to Boolean union the pattern. :)
EDITED: 22 Sep 2011 by SBEECH
Show messages:  1-8  9-28  29-48  49-68  69-79
