Flow Test
 1-16  17-36  37-56  57-76  77-79
4487.17
Thanks Pilou!
No just a random set of shapes.
4487.18
Flow to a Toroidal Knot using bemfarmers' excellent script. Thanks bemfarmer!
Rendered in Modo:
EDITED: 2 May 2023 by SBEECH
4487.19 In reply to 4487.18
Cool pattern! Just imagine trying to model that one directly in place in 3D...
Cool image!
Like Topmod Model! http://code.google.com/p/topmod/
It's a Moi script? have you the link?
4487.21 In reply to 4487.20
Hi Pilou - Bemfarmer's toroidal knot plug-in here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4430.1
Many thanks!
Damned, this was released in August when I was not here!
So missed!
Ps I have made some publicity around the world of your previous images in some forum 3D :)
(and of course flow Moi function ;)
4487.24 In reply to 4487.18
Holy cats Danperk!! That thing is incredible!
4487.25
Thanks Mike, not skill, just trickery. ;)
4487.26 In reply to 4487.21
Great Flow example!
I've got to try one. I do have Alibre and Keyshot 2, but it only takes .bip format.
The toroidal knot script is about 99% copied from Michaels Toroidal Helix script, with I think, one added parameter.
@danperk
Does the rectangular pattern are separated objects or just one object boolean union?
from my tests both is working
but maybe one is best than some?
EDITED: 21 Sep 2011 by PILOU
4487.28 In reply to 4487.27
They were separated objects. As you say, both would work but it's easier to modify the pattern as separated items.
I use the CurveLengthV2 script to copy/paste the width/height from destination object to rectangular base object.
From Petr's MoI page:
http://kyticka.webzdarma.cz/3d/moi/
http://plugmoi.voila.net/index.htm
PS. If you wanted to manufacture this object, it would be better to Boolean union the pattern. :)
EDITED: 22 Sep 2011 by SBEECH
4487.29 In reply to 4487.28
Thx for the infos!
4487.30
vois ĂȘtes les bienvenus!
More Toroidal flow madness, captured in Acrobat & comped in Photoshop:
Remember that i have made with topmod ;)
4487.32 In reply to 4487.1
danperk
this exercise is excellent. in which program did you render the blue image?
also how you control the density of the pattern applied to the sphere?
could it be twice as dense as on your blue image? ...and how you controle it.
i only had limited chance to play with new tool and for what i do (i am an architect working on large international projects) it seems to be
golden tool. i would appreciate your opinion.
4487.33 In reply to 4487.1
how does flow differ from flow along surface in rhino
regards
4487.34 In reply to 4487.33
Hi Christopher,
It's equivalent to the "Flow" and "FlowAlongSrf" commands in Rhino.
The main differences are that in MoI instead of having a separate command for flowing between curves or flowing between surfaces there is just one command that just pays attention to whether you pick a curve or a surface as the initial base object.
Also one other difference is that in the next v3 beta there will be a new "projective" option that will apply the object in a different way - I don't think that Rhino's flow has an exact equivalent of that.
See here for some examples of the new projective option which will be coming to Flow in the next MoI v3 beta:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4471.15
4487.35 In reply to 4487.32
Thanks mario, I'm having fun with the new Beta!
>>in which program did you render the blue image?<<
If you mean the second image in my first post it's just a screen capture of an Adobe Acrobat file,
you can download the attached PDF file that's at the bottom of the first post called FlowCelt.PDF.
>>also how you control the density of the pattern applied to the sphere?<<
The pattern density is controlled by the number of copies in the original which you see on the flat plane
you see in the first image-first post.
Here is the same pattern with double the density mapped to the left sphere:
EDITED: 18 Oct 2018 by SBEECH
4487.36 In reply to 4487.35
danperk
thanks for the reply
do we need to do anything else to have it so perfectly applied to the sphere?
does the size of the flat pattern matter compared to the size of sphere you are applying the pattern to?
i am going to try more now!!
regards
mario
Show messages:  1-16  17-36  37-56  57-76  77-79
