Flow Test
 1-11  12-31  32-51  52-71  72-79
4487.12
Thanks Rich, quick contour and occlusion render from Modo.
Design!
4487.14 In reply to 4487.12
Cool look with the edge contours included!
4487.15
Thanks Guys! Yes, I like the illustrated look of contours. :)
Last test with this one, example of using flow on the results of a flow....
EDITED: 8 Dec 2013 by SBEECH
Cool PDF 3D!
Is that a theater?
4487.17
Thanks Pilou!
No just a random set of shapes.
4487.18
Flow to a Toroidal Knot using bemfarmers' excellent script. Thanks bemfarmer!
Rendered in Modo:
EDITED: 2 May 2023 by SBEECH
4487.19 In reply to 4487.18
Cool pattern! Just imagine trying to model that one directly in place in 3D...
Cool image!
Like Topmod Model! http://code.google.com/p/topmod/
It's a Moi script? have you the link?
4487.21 In reply to 4487.20
Hi Pilou - Bemfarmer's toroidal knot plug-in here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4430.1
Many thanks!
Damned, this was released in August when I was not here!
So missed!
Ps I have made some publicity around the world of your previous images in some forum 3D :)
(and of course flow Moi function ;)
4487.24 In reply to 4487.18
Holy cats Danperk!! That thing is incredible!
4487.25
Thanks Mike, not skill, just trickery. ;)
4487.26 In reply to 4487.21
Great Flow example!
I've got to try one. I do have Alibre and Keyshot 2, but it only takes .bip format.
The toroidal knot script is about 99% copied from Michaels Toroidal Helix script, with I think, one added parameter.
@danperk
Does the rectangular pattern are separated objects or just one object boolean union?
from my tests both is working
but maybe one is best than some?
EDITED: 21 Sep 2011 by PILOU
4487.28 In reply to 4487.27
They were separated objects. As you say, both would work but it's easier to modify the pattern as separated items.
I use the CurveLengthV2 script to copy/paste the width/height from destination object to rectangular base object.
From Petr's MoI page:
http://kyticka.webzdarma.cz/3d/moi/
http://plugmoi.voila.net/index.htm
PS. If you wanted to manufacture this object, it would be better to Boolean union the pattern. :)
EDITED: 22 Sep 2011 by SBEECH
4487.29 In reply to 4487.28
Thx for the infos!
4487.30
vois ĂȘtes les bienvenus!
More Toroidal flow madness, captured in Acrobat & comped in Photoshop:
Remember that i have made with topmod ;)
Show messages:  1-11  12-31  32-51  52-71  72-79
