Trimmed Surface Restoration
All  1-3  4-6
4482.4 In reply to 4482.1
Hi Mike, check out the object repair tutorial for a pretty in depth covering of that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
Also here's a shorter one focused just on how to untrim:
http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
You basically need to get the boundary that you want to remove to be made up of all unjoined edges (delete things or use Edit > Separate as necessary) then select all the edges of the boundary you want to remove and push delete to remove that trim boundary and restore the underlying surface there.
If you want to untrim everything on a surface, select one edge and then do Ctrl+A to select all its edges before pushing delete.
There's also a plug-in "UntrimAll" which gives a shortcut for untrimming everything in a whole solid in one step here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4068.6
4482.5 In reply to 4482.3
Hi Mike, yup the seam is a bit tricky - when a trim boundary touches a seam the seam edge is a part of the whole boundary and so it must also be selected in order for it to recognize that you're trying to remove the entire boundary.
I suppose that could be tuned up so that you wouldn't have to pick the seam, I've added a note to myself to look into that.
4482.6 In reply to 4482.5
Thank a million Michael!
That was so easy, I'm not surprised I missed that ability all this time.
I played around with it and found out how using ShrinkTrimmedSrf in conjunction with it can give you neat residual surfaces to work from when bringing back the (secondary) trim surfaces themselves from the dead.
Speaking of the seams...
I can hide them individually as sometimes they seem to be more or less clutter on an object. But then again, when they are useful, you need to see them there.
If I could make a teensie request, it would be to allow for a separate coloration setting in the .ini. I myself might make them a barely visible gray.
Or turn them off from visibility completely, say, unless you select the whole object then it is visible.
But this is just the "modder" in me asking. :-)
Thanks again!
Show messages: All  1-3  4-6
