Bug Report
All  1  2-5
4473.2 In reply to 4473.1
Hi Brian, thanks for reporting this bug.
This is a bug in the processing of curve intersections for intersection object snap. So it can potentially happen in anything that picks a point.
I've got it fixed up now for the next v3 beta.
It's actually a bit different than a regular crash bug - this one is a warning that something was not structured as expected in the intersection results. But it actually happens that the messed up result is not actually used so it is possible to just ignore this particular one - unlike a regular crash bug this kind of warning message popup has an "ignore all" button that you can push and you should actually be able to continue running MoI ok after doing that.
Also this is far more likely to be triggered when calculating the intersection on projected curves, so if you keep running into it you could turn off projected intersections until the next v3 beta. That's under Options > Snaps > Object snap options > "use apparent intersections".
4473.3 In reply to 4473.2
Hi Michael G.
The separate 3dm2dxf application does not seem to work with files saved in the beta v3 version in MoI. I re-opened the file in v2 and saved it, then ran the 3dm2dxf application and it converted fine.
Just thought I would point this out.
Michael T.
4473.4 In reply to 4473.3
Hi Michael T - thanks for reporting this.
That's likely caused by a change that MoI v3 writes out Rhino v4 3DM files, and that tool will only read Rhino v3 3DM files.
At some point I'll either update that tool or make it unnecessary by having DXF export built in instead.
4473.5 In reply to 4473.4
The later would br awesome!
Michael T.
Show messages: All  1  2-5
