How to make a Klein bottle?
 1-6  7-22
4469.7 In reply to 4469.6
< But you will never get a true solid because it is impossible...
I believe that you are wrong ;)
You must just find material that accept immersion submergence ;)
Take a look here ;)
http://www.kleinbottle.com/meter_tall_klein_bottle.html
Some technical material needing but result astonished!
4469.8
But the solid is the surface.
Rudl
4469.9 In reply to 4469.8
A surface with a tickness is also a solid :)
4469.10 In reply to 4469.9
Thats just a fakeout Frenchy!!! Physics makes it imposible.. There needs to be a 4th dimension.
Here's my model:
https://skydrive.live.com/?cid=641344b395278ed0&sc=documents&uc=1&id=641344B395278ED0%21175#
Here is the conundrum highlighted with "get naked edges"...
I don't see any 4D inside that :)
You can built this very easily
So that is a Klein's Cube? Yes you right :)
From JP Petit "Le topologicon" all about Topology in very undestanding in Comics book format PDF !
Exist in English (it's free ;)
Choose your language
here the Topologicon http://www.savoir-sans-frontieres.com/JPP/telechargeables/English/topo_the_world_eng.htm
Here all the books on some scientic subjects : All is free: a true gem !
And you translate some books if you want!
4469.12
The Klein bottle shown is not a fake. In your model you need to make 2 holes. One where the naked edge is and one at the base. There is nothing difficult about extending the neck in through the bottle and out the base. However, your bottle needs to have some thickness to allow correct connections, just like a real one. What you cannot have in reality is a single surface with no thickness.
4469.13 In reply to 4469.12
""""""""The Klein bottle shown is not a fake.""""""""""""
The Klein bottle is a concept of a bottle that contains itself..
"""""""" In your model you need to make 2 holes. One where the naked edge is and one at the base."""""""""
At some point, the "surface" would have to travel through itself.. This is not possible. Could you demonstrate with a model about the extra holes you are refering too?
Sure you can blob glass together at that conundrum, but it is not a true "klein bottle".
4469.14
Here is my MoI Solid model Klein Bottle. Does this solve the problem?
Michael T.
4469.15 In reply to 4469.14
The part thats the "fake out" is that, if you look at Michael's model, at some point, the "open part" becomes the "some thickness part".
For instance, what can go inside of or is there an inside of 1/2 inch thick metal bar???
This is my statement that it is fake.. It cant be done. (in reality)
4469.16 In reply to 4469.15
Burr, Can you show me where mine is a fake? I have not checked it into any other systems yet, but would appreciate the feedback.
thanks
Michael T.
4469.17 In reply to 4469.16
http://www.youtube.com/watch?v=Ra62LW6NuGk
video of a klein bottle in a guy's hand
4469.18 In reply to 4469.16
Hi Michael T.
"""""Burr, Can you show me where mine is a fake? I have not checked it into any other systems yet, but would appreciate the feedback."""""
Let's see if this can do it..
It's been stated that "you cant do it with a surface, but you can do it with a SOLID"..
Here I have seperated out your surfaces. Showing the main part of the body. I colored the exterior as REd to note the 2 different pieces.. The original color is your grey color... This would be exclaimed as "solid" (The space in between the grey and red is some type of "material"...
Here I have added the surface that is connected to the grey "inside surface" of the "thickness".. This would denote that the exterior of the orange surface is "Solid" or some type of material..
If you follow that down into where it penetrates the large body again, you will discover that the solid becomes the space..
Someone needs to explain to me how "Glass" can do that...
4469.19 In reply to 4469.18
Hi Burr,
Here is a section cut view of the part. I'm still not sure what you mean. Sorry for my thick-headedness :-)
Michael T.
4469.20
Hi Burr, do you mean something like this surface model as opposed to the solid model?
4469.21 In reply to 4469.19
Hi Michael T,
No, you are correct and I misread your model.. Thanks for following through with that for me.. (What do you type for the embarrassment smiley again???)
4469.22 In reply to 4469.21
Thanks Burr.
"(What do you type for the embarrassment smiley again???)"
Not sure, but I myself would have to use it a lot! :-)
Michael T.
Size: 194 KB, Downloaded: 56 times, Dimensions: 1280x1024px
Show messages:  1-6  7-22
