Flow-jagged curve outcome
All  1-2  3-5
4468.3 In reply to 4468.1
You might also see if placing both the base line and the target curve down on to the world x/y plane (like rotating them by 90 degrees so they are flat in the Top view) makes it behave better. Looks like there may be some kind of bug with dealing with things going in a vertical direction right now.
4468.4 In reply to 4468.3
Michael,
reducing the number of turns appears to reduce the amplitude of the sawthooth pattern but it does not remove it by any means. Turning the curves over on their sides does fix the problem (regardless of the number of turns). I have included the file just in case you still want it...thanks for the help.
possum
4468.5 In reply to 4468.4
Thanks for the file possum - there definitely looks like a bug there to track down.
In the meantime it does appear that if you keep both curves to be within the world x/y plane instead of going in a vertical direction it should work better.
Show messages: All  1-2  3-5
