Catenary Script
All  1-7  8-13
4454.8 In reply to 4454.7
I never tried version 2......should have...
Edit: 3/23/2012 Replaced Catenary2PtXY with slightly modified htm. Now works with MoI version 2 (Windows)
(Had an extraneous line of code in the htm.)
Do not have a Macintosh. Perhaps someone will try it out there?
4454.10 In reply to 4454.9
Just downloaded it bemfarmer, I'll give it a spin.
Michael T.
4454.11 In reply to 4454.9
That did the trick bemfarmer. Works great in v2 now!
Michael T.
Note: this is an Unofficial script, by an amateur programmer...
The script works pretty good. It needs an adjustment to "aGuess" if the two points are close together, "relative" to the arclength S.
Values of .1 to .5 seem good in that situation. Some additional code to assist NewtonRaphson may be in order.
Here is an updated script which will Also accept points with different z values.
Gravity is still in the -y direction. The two points cannot be vertically one above the other.
Also attached the rambling PDF about catenaries, which has been edited numerous times, but may still have errors...
Just added in a coordinate frame, using previous explainations of Michael, to temporarily rotate the x-axis about the new parallel y-axis, which effectively converts
the z coordinates to zero, so that the prior Catenary2PtXY code is re-used.
Changing the direction of gravity, or finding S given "a," have not been done.
EDITED: 8 Nov 2012 by BEMFARMER
Here is the old simple catenary script which seems to have been deleted sometime.
Removed an extraneous line of code which MoI4 picked up as an error.
Works for MoI3 and MoI4Feb2018beta.
Show messages: All  1-7  8-13
