Network Curve selection
All  1-7  8-9
4453.8 In reply to 4453.7
I have take some IGS files and convert them polygon models, proably sub-d at that.
I know MOI won't give me a perfect Mesh for that sort of thing. But if I can do anything to reduce my work on the polygon side of the pipeline it helps. Worse case I can do a retopo in 3d coat.
I'm also starting to have to reproduce items, cars etc, that were clearly made in a nurbs package.
But having to build them with sub division modelling is a pain.
Using MOI just to produce a fast low res model can be a big help on the poly modeling side.
EDITED: 28 Aug 2011 by MASH3D
4453.9 In reply to 4453.8
Hi mash - yeah basically MoI (with the n-gon option active) builds a mesh that resembles and follows the same topology as the NURBS object - things like one n-gon face for one trimmed planar NURBS surface, etc...
That's a nice clean structure in a lot of ways, like not a lot of extra wires but it's just a generally different kind of structure than what you'll need for sub-d except in particular special cases like with untrimmed surfaces.
But that's great that you've got 3d-coat and can use that for retopo if needed.
I just wanted to clarify that - it's kind of a frequent thing that people see Moi's structured n-gon output and seem to automatically jump to the conclusion that a clean looking wireframe and organized looking topology equates to sub-d friendly topology, when that's not necessarily the case.
If you are looking to produce a rendering of your models, you can just render MoI's output directly - it includes vertex normals with the output which helps things look smooth in the rendering without having to apply any sub-d smoothing on it at all.
Show messages: All  1-7  8-9
