Trying to go with the Flow
All  1-13  14-16
4452.14 In reply to 4452.13
Yes - The rectangle plane (called the Base Surface) is the width of the ring and its length is pi x diameter of the ring.
The extruded hearts design must intersect the Base Surface so that it will intersect the Target Surface (the ring surface) by the same amount.
Apply the Flow command and Boolean Diff the wrapped design leaving the design recessed into the ring. Finally, apply Fillet to the ring.
Ed
4452.15 In reply to 4452.14
Thanks Ed
How do you control the direction the flow goes on
I did a test word that insists on flowing across the ring not around it (no matter where I select the parts)
I'm stumped
ps for Michael
After assigning objects a name you cannot click on their name in the object area to select them
thanks
shayne
4452.16 In reply to 4452.15
Hi shayne,
> I'm stumped
Right now it always maps from the built-in UV direction of one surface to the UV direction of the other surface.
In your particular case the U and V directions on the revolved piece are reversed from what you need.
To fix this currently you need to alter your base surface - try squishing it to be narrow and tall and then rotate it 90 degrees and then use it as the base surface.
I am working on a way to control how the surfaces relate to one another more easily for the next v3 beta.
There's a new selection indicator area at the right-hand side of the name - click there now to do the selection. See here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4438.21
Show messages: All  1-13  14-16
