 1-19  …  920-939  940-959  960-979  980-999  1000-1019  …  3100-3119
4446.960 In reply to 4446.959
Very cool!
A cool free one!
Classical relax with the free MagicaVoxel! :)
4446.963
SDF Edit has been released, and renamed to MagicaCSG:
http://ephtracy.github.io/index.html?page=magicacsg
More info and demo videos here:
https://blenderartists.org/t/new-signed-distance-fields-editor-by-the-creator-of-magicavoxel/1293075
Regards,
Metin
4446.964 In reply to 4446.963
Excellent!
EDITED: 21 May 2021 by PILOU
A new concept of modeling object by object to manage! :)
Let's go first crazy with MagicaCSG and my little prog that you can use! https://editor.p5js.org/Pilou/full/y1GHaBqyT
Just make a transparent png image with some of your modules and drag and drop them !
A transparent PNG image with anything but also some free space!
and of course can be used with any moi3D objects! (my little prog not the MagicaCSG :)
And surprise following your inside image! 8-)
4446.967
Yeah, MagicaCSG is a lot of fun!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
Gizmo rotate the object material itself! So hallucinated forms! Maybe a little training is necessary for master that! :)
Artists are in the starting blocks! :)
By ManXiaoMisaki
Astonished Magicavoxel free Kitbash for SF & CyberPunk (video of use inside the site)
https://gumroad.com/l/voxelkitbash
By Paul Riehle
EDITED: 22 May 2021 by PILOU
4446.970 In reply to 4446.969
Amazing model!
Mik
Free Kitbash above by Hifoo/ Paul Riehle is a killer one! keys 9,0,= a delight! (for free MagicaVoxel https://ephtracy.github.io
here following a same element rotated, positive, negative etc...
How to simulate a "stereographic" 3D model from the MagicaVoxel rendering engine?
Retrieve the "straight" OBJ object from Magica, better to clean up the coplanar faces with your favorite 3D program, project it onto the volume of your choice (here a half-sphere). The object will then have a thickness, and will be completely "3D Printable". It is funny to see that a "curvated" building becomes curiously a spaceship!
Once again the free"Kitbash" free is full of infinite richness of possibilities! Bravo to Paul Riehle / hifoo!
EDITED: 25 May 2021 by PILOU
4446.973 In reply to 4446.972
Beautiful!
4446.974 In reply to 4446.973
Very inspirative!
Mik
Cool use of Blender and other true gems!
Infinite textures from free JsPlacement (can of course be used for Moi Objects) https://windmillart.net/?p=jsplacement
Then free FileToVvox by Zarbuz https://github.com/Zarbuz/FileToVox & render free MagicaVoxel https://ephtracy.github.io
From free Jsplacement & free filetox by Zarbuz for the free MagicaVoxel...
you can export obj format so possible import inside moi! ;)
EDITED: 3 Jun 2021 by PILOU
4446.979 In reply to 4446.978
Cool.
It seems a motherboard.
Show messages:  1-19  …  900-919  920-939  940-959  960-979  980-999  1000-1019  1020-1039  …  3100-3119
