 1-9  …  890-909  910-929  930-949  950-969  970-989  …  3110-3119
Abstract Landscape by Taron with its Vervette SandBox above! ;)
Totally amazing!
4446.933
quote:
This is an online edition of the classic technical reference Five Hundred and Seven Mechanical Movements by Henry T. Brown. This site contains the original illustrations and text from the 21st edition of the book, published in 1908. It also includes animated versions of the illustrations, and occasional notes by the webmaster. The animated versions are not yet complete. They are identified by color images in the thumbnail pages. To keep up with developments on this site, use the Twitter Follow or Facebook Subscribe links below.
http://507movements.com
4446.934
quote:
Welcome to Animated Engines! Here you’ll find animated illustrations that explain the inner workings of a variety of steam, Stirling, and internal combustion engines.
http://animatedengines.com
4446.935 In reply to 4446.934
Excellent and a cool prog for adapt them!
Free Algodoo! ;)
http://www.algodoo.com
EDITED: 30 Mar 2021 by PILOU
4446.936
https://plasmo.ai/ neat approach !
- Tudor -
4446.937 In reply to 4446.936
Super cool!
Absolutly fascinating!
https://virtualcreatures.github.io
I put here the more artistic!
Lenia : can be played online - a little special! : https://chakazul.github.io/Lenia/JavaScript/Lenia.html
By bert Chan
Polygons on steroids! :)
Another funny one! More you draw more it's free!
EDITED: 21 Apr 2021 by PILOU
Free MagicaVoxel https://ephtracy.github.io/
no more need to enter shader inside the Console : All by the UI!
Try with the shaders by Mode_vis! https://gumroad.com/mode_vis?sort=newest
That works like a charm!
My test of a FerroFluid! :)
EDITED: 25 Apr 2021 by PILOU
Animation from your videos!
And it's free!
Made with Blender!!!
EDITED: 28 Apr 2021 by PILOU
Make volumes for 3D Printing in the Free MagicaVoxel!
Pattern is done in Magica, you can import an OBJ objects from Moi by Drag & Drop or build anything with Magica.
Fractal classic function but...
Matrix is filled with any cubical volumes. Press Fractal for replace all cubes by the Pattern!
Unitary Matrix maxi : 256 256 256
Each cube is now the Pattern but with only color! Press Tex for have all colors' Pattern on each cube!
It's here that you can make anything you want like select "Green" color and erase it for have only a wire buildable for the 3D Print!
For Render in MagicaVoxel ( F1) maybe you can see nothing...
it's because in Mode World (Tab) volumes are under the Ground! Just up them!
MagicaVoxel again (free)
A Ferro-Fluid https://en.wikipedia.org/wiki/Ferrofluid
With crazzy Shaders by Mode_vis https://gumroad.com/mode_vis?sort=newest
4446.948
I don't know if this has already been mentioned here, but the skilled developer of MagicaVoxel is working on an exciting new tool based on Signed Distance Fields: SDF Edit.
He is frequently posting video previews on Twitter:
https://twitter.com/ephtracy
I'm really looking forward to having a go at the tool when it's released.
From Magica...:)
Show messages:  1-9  …  870-889  890-909  910-929  930-949  950-969  970-989  990-1009  …  3110-3119
