 1-19  …  840-859  860-879  880-899  900-919  920-939  …  3100-3119
4446.880
I made a suggestion to Meshlab to add an option to reverse the wheel mouse direction. They accepted it and it is in version 2020.07. https://www.meshlab.net/
EDITED: 8 Jul 2020 by WAYNEHILL5202
Amazing thing!
Free!
Amazing and free!
https://cascadeur.com
4446.885
https://www.daz3d.com/flowscape-tutorial
tuto flowscape by the developer Chris Hunter ( 1 h 35 min )
sympathique créateur du sympathique Flowscape ... entre 2 séances de Vue xtream ou Lumion ... ça détend ;)
EDITED: 9 Sep 2020 by CORCHET
4446.886 In reply to 4446.885
Cool cela complètera mon manuel! :) VF
https://moiscript.weebly.com/flowscape.html
Flowscape is true gem! I am a big fan of it!
see https://moi3d.com/forum/index.php?webtag=MOI&msg=4446.791 and following! :)
EDITED: 6 Aug 2020 by PILOU
Sorry not 3D but can be useful for musicians! :) (Free)
4446.888
Materialize -- An AMAZING Free Texture Map Generating Tool
download here
https://www.boundingboxsoftware.com/materialize/index.php
how to here
https://www.youtube.com/watch?v=vtnJToPxBNo
excellent FREE PBR material creator !
4446.889 In reply to 4446.888
Great finding: very many thanks !
4446.890
http://jenn3d.org/
jenn3d is an old freeware ( jenn3d_win_2013_06_20.zip ) .. it generates a lot of geometric structures some very nice ! some very complex !
works on any windows - the diameter of the elements can be reduced or enlarged
easy to use - the 3d file is named " jenn_export.stl " ... no choice ... so don't forget to rename the several models
01 jenn 02 jenn etc ... STL ... convert in .obj ( for example in Meshlab )
the parts are not joined so it's easy to delete unwanted tubes or spheres to keep interesting structures
examples imported in Max ... and with a remeshing in quads, the import in Moi is very quick
4446.892 In reply to 4446.891
Seems 3dm or OBJ are not on board! :)
Supported file extensions include .3dxml .CATPart .dwg .dxf .iges .igs .ipt .jt .model .par .prt .sab .sat .sldprt .step .stl .stp .vda .x_b .x_t .xcgm .xml .
EDITED: 22 Aug 2020 by PILOU
Not sure that complexify it is a good thing! :)
Modernity! :)
Tricky things :)
EDITED: 26 Aug 2020 by PILOU
MagicaVoxel new version 0.99.5.6 (missed :)
https://ephtracy.github.io
New shaders (free) for many things! (40) here by Mod_vis : https://gumroad.com/mode_vis
like this one
EDITED: 30 Aug 2020 by PILOU
MagicaVoxel
Generative city...
https://twitter.com/i/status/1301184556410822656
Always fun the free MagicaVoxel! Makes not only cubes! Cherries' time!
Show messages:  1-19  …  820-839  840-859  860-879  880-899  900-919  920-939  940-959  …  3100-3119
