 1-13  …  834-853  854-873  874-893  894-913  914-933  …  3114-3119
4446.874 In reply to 4446.873
nice !
- Tudor -
Play on line reduced version https://oskarstalberg.com/game/house/index.html
Here with a planet https://oskarstalberg.com/game/planet/planet.html
And for all understand
Terrific! Seems number of levels are infinite! :)
Not the map hoppefuly :)
EDITED: 3 Jul 2020 by PILOU
Totally addictive and regressive! :)
Tensegrity you have to see it to believe it! Amazing!
About tensigrity above :)
The creator of that! R.Buckminster Fuller
The wires on the sides play the role of shrouds on a boat!
They prevent the top piece from falling from one side or the other!
You can understand it better if you imagine this!
The wire becomes "solid"! The side shrouds become useless!
It is the bottom piece that "holds" the top piece!
4446.880
I made a suggestion to Meshlab to add an option to reverse the wheel mouse direction. They accepted it and it is in version 2020.07. https://www.meshlab.net/
EDITED: 8 Jul 2020 by WAYNEHILL5202
Amazing thing!
Free!
Amazing and free!
https://cascadeur.com
4446.885
https://www.daz3d.com/flowscape-tutorial
tuto flowscape by the developer Chris Hunter ( 1 h 35 min )
sympathique créateur du sympathique Flowscape ... entre 2 séances de Vue xtream ou Lumion ... ça détend ;)
EDITED: 9 Sep 2020 by CORCHET
4446.886 In reply to 4446.885
Cool cela complètera mon manuel! :) VF
https://moiscript.weebly.com/flowscape.html
Flowscape is true gem! I am a big fan of it!
see https://moi3d.com/forum/index.php?webtag=MOI&msg=4446.791 and following! :)
EDITED: 6 Aug 2020 by PILOU
Sorry not 3D but can be useful for musicians! :) (Free)
4446.888
Materialize -- An AMAZING Free Texture Map Generating Tool
download here
https://www.boundingboxsoftware.com/materialize/index.php
how to here
https://www.youtube.com/watch?v=vtnJToPxBNo
excellent FREE PBR material creator !
4446.889 In reply to 4446.888
Great finding: very many thanks !
4446.890
http://jenn3d.org/
jenn3d is an old freeware ( jenn3d_win_2013_06_20.zip ) .. it generates a lot of geometric structures some very nice ! some very complex !
works on any windows - the diameter of the elements can be reduced or enlarged
easy to use - the 3d file is named " jenn_export.stl " ... no choice ... so don't forget to rename the several models
01 jenn 02 jenn etc ... STL ... convert in .obj ( for example in Meshlab )
the parts are not joined so it's easy to delete unwanted tubes or spheres to keep interesting structures
examples imported in Max ... and with a remeshing in quads, the import in Moi is very quick
4446.892 In reply to 4446.891
Seems 3dm or OBJ are not on board! :)
Supported file extensions include .3dxml .CATPart .dwg .dxf .iges .igs .ipt .jt .model .par .prt .sab .sat .sldprt .step .stl .stp .vda .x_b .x_t .xcgm .xml .
EDITED: 22 Aug 2020 by PILOU
Show messages:  1-13  …  814-833  834-853  854-873  874-893  894-913  914-933  934-953  …  3114-3119
