 1-10  …  711-730  731-750  751-770  771-790  791-810  …  3111-3119
Crazzy! (move with your mouse for amplify the "rotations" :)
https://cables.gl/p/lipIpP
EDITED: 29 Aug 2019 by PILOU
Not opposite because it's only Moi Objects! :)
Just for validate a cool flow of modeling! Only Blending surfaces in 5 seconds! :) (time to select curvated edges)
Cut the result in 2 parts - Shell - (here twice the same from 2 different views)
EDITED: 3 Sep 2019 by PILOU
MagicaVoxel comes back with the Intel Denoiser integrated! ;)
Intel Open Image Denoiser [0.99.4.2]
Requirement: 64bit system, 4GB memory
Installation: download plugin.zip and extract the content to the program folder. (menu Win64 or MacOs plugin) https://ephtracy.github.io
Image->Filter->Denoise: denoise rendered images in the preview mode. use mouse wheel to zoom in/out, left-drag to move image.
Image->MRT: render additional albedo and normal images to help the denoiser to preserve details. note that it does not always improve the quality.
Sample->Bounce->Clamp: clamp energy to reduce noises.
Image based Lighting [0.99.4.1]
Sky->IBL: Image Based Lighting. use ".hdr" format panorama images to light the scene.
Fog: add Equi-angular sampling back to reduce noises. support fogs in othogonal views in a bounding volume.
Media: enable Sample->TR-Shadow to allow single direct lighting; enable Sample->MIS-Cloud to allow multiple direct lighting (very expensive).
Color all color options have their own color pickers which support HSV, RGB, H-Block and Hex values.
Palette Menu right click the palette view to show the pop-up menu.
https://twitter.com/i/status/1169292160400875526
4446.754 In reply to 4446.753
Great to know!
Thanks Pilou!
Have you some success with this denoiser one ? (line command) :) All run fine except absolutly noting as result for me ! :)
i have of course Nvidia ...
https://declanrussell.com/portfolio/nvidia-ai-denoiser/
yes ok...Created by Declan Russell (25/12/2017 ~ Merry Christmas!)
yes ok ...Input image: C:/Location of image to be denoised/noiseyImage.jpg
yes ok ...Loaded successfully
yes ok...Output image: C:/Location to save image/denoisedImage.jpg
nothing...Denoising…
nothing...Denoising complete
nothing...Saving to: C:/Location to save image/denoisedImage.jpg
nothing...Done!Voxel
Do you know an another cool one(s) free "Standalone" denoiser with the new AI technology?
This one but but it's not exactly a stand alone :)
... and alas this one following is mess to install (for me :)
https://github.com/DmitryUlyanov/deep-image-prior
EDITED: 20 Sep 2019 by PILOU
Not exactly the opopsite because without my glass i had believed that was moi3D ! :)
The shapr3D program looks interesting.
Todays email mentioned TikZ. Update as of September 2019.
The new manual is a mere 1244 pages.
So far, no opinion on this program:-)
From Moi to the free Twinmotion in using the new interface by Wayne! ;)
here _sSplit _SBridge _Subdiv9
Inset
EDITED: 15 Oct 2019 by PILOU
Careful when you import Moi Object inside Twinmotion Scale is generally necessary
as you have several colors as material you must careful to selected all colors for scale the entiere object!
Else you can imagine that something don't works!
EDITED: 16 Oct 2019 by PILOU
4446.762 In reply to 4446.761
XD
By Ephtracy the Autor of MagicaVoxel (so same ergonomy for the render! :)
Aerialod (free)
An interactive path tracing renderer for height maps.
support rendering height maps of size up to 16384^2.
support importing and exporting 8-bit and 16-bit png images
I am waiting the Strereographic projection (buttons are existing! ;)
EDITED: 23 Oct 2019 by PILOU
ZBrush 2020 (12 November)
All videos by Aujik are crazzy!
4446.768 In reply to 4446.767
A-M-A-Z-I-N-G !!!
Thanks!
Not sure that is an easy program :) (it has an ELEPHANT under steroïds :)
4446.770 In reply to 4446.769
"Not sure that is an easy program"
A very complex one, indeed!
Show messages:  1-10  …  691-710  711-730  731-750  751-770  771-790  791-810  811-830  …  3111-3119
