 1-20  …  701-720  721-740  741-760  761-780  781-800  …  3101-3119
I think it depends on your use case. If you are an Industry
Professional people go with ZBrush. If you are a hobbyist
people go with 3DCoat.
I have both and I love Zbrush much much more than 3DCoat.
The brushes in ZBrush are more fluid and ZBrush can handle
on small machines much more geo than 3DCoat.
The only thing were 3DCoat is better is in it's
PBR painting tool set and image to mesh functionallity.
And last but not least, 3DCoat is in permanent beta state ...
So always little bugs which will be fixed in the next beta and
so on.
EDITED: 27 Jul 2019 by STEFAN
4446.742 In reply to 4446.740
Hello Brian!
3DC is overall a great choice!
If you have a capable machine (with good CPU/GPU) it can offer a very powerful environment with tons of tools.
Maybe it's UI can be still a little messy in some aspects and, as said by Stefan, some of its powerful tools are still in beta, but its PBR Painting Room and its Voxels and also other tools are amazing.
As said by Stefan "...If you are an Industry Professional people go with ZBrush.".
This is actually true.
But the second part of the phrase "...If you are a hobbyist people go with 3DCoat"
I don't know how or where Stefan took this idea, but many many professional artists and designers, especially for game industry, uses 3DC daily into their pipelines with GREAT results.
It depends on what you have to do, but at that price tag, 3DC is a cornucopia of very powerful tools!
Hi Marco,
sorry, I meant more the price tag, which is affordable for hobbyist,
compared to the price tag of ZBrush. And yes, it is true about
Game Industry Professionals, which I forgot to mention, because
I have no overview of the Gaming World, sorry!
4446.744 In reply to 4446.743
No problem Stefan! :)
I only wanted (hoped) to give a more complete view over 3DC.
Both ZB and 3DC are amazing tools!
ZB is super powerful but also it has a steeper learning curve.
Thankyou Stefan and Marco.
There is a little difference for 3D Coat: you can modelize entierely from "Voxel" (microscopic cubes)
and at the end transform in classical OBJ polygonal format.
ZBrush has not this function (only hidden for the user for few functions (Unify Skin, ShadowBox...)
And modelise by ZBrush "Shadow Box" Plane by Plane is not the same than 3dCoat
Another difference : 3D Coat has a classical Interface! ;)
EDITED: 27 Jul 2019 by PILOU
4446.748
https://cables.gl/home
Cables is a visual programming environment to create interactive content for the web.
Another "Node" fetish :-)
4446.749 In reply to 4446.748
Seems very cool indeed! (Elephant on steroîds :)
EDITED: 21 Aug 2019 by PILOU
4446.750
The Blender 2.81 master builds now include Intel's AI-powered Open Image Denoiser (OIDN). It's quite impressive what it can already do with a one-sample rendering:
https://twitter.com/simonthommes/status/1164202286027030529
Have a nice weekend,
Metin
Freelance visualizer • illustrator • animator • 3D designer — metinseven.nl
Crazzy! (move with your mouse for amplify the "rotations" :)
https://cables.gl/p/lipIpP
EDITED: 29 Aug 2019 by PILOU
Not opposite because it's only Moi Objects! :)
Just for validate a cool flow of modeling! Only Blending surfaces in 5 seconds! :) (time to select curvated edges)
Cut the result in 2 parts - Shell - (here twice the same from 2 different views)
EDITED: 3 Sep 2019 by PILOU
MagicaVoxel comes back with the Intel Denoiser integrated! ;)
Intel Open Image Denoiser [0.99.4.2]
Requirement: 64bit system, 4GB memory
Installation: download plugin.zip and extract the content to the program folder. (menu Win64 or MacOs plugin) https://ephtracy.github.io
Image->Filter->Denoise: denoise rendered images in the preview mode. use mouse wheel to zoom in/out, left-drag to move image.
Image->MRT: render additional albedo and normal images to help the denoiser to preserve details. note that it does not always improve the quality.
Sample->Bounce->Clamp: clamp energy to reduce noises.
Image based Lighting [0.99.4.1]
Sky->IBL: Image Based Lighting. use ".hdr" format panorama images to light the scene.
Fog: add Equi-angular sampling back to reduce noises. support fogs in othogonal views in a bounding volume.
Media: enable Sample->TR-Shadow to allow single direct lighting; enable Sample->MIS-Cloud to allow multiple direct lighting (very expensive).
Color all color options have their own color pickers which support HSV, RGB, H-Block and Hex values.
Palette Menu right click the palette view to show the pop-up menu.
https://twitter.com/i/status/1169292160400875526
4446.754 In reply to 4446.753
Great to know!
Thanks Pilou!
Have you some success with this denoiser one ? (line command) :) All run fine except absolutly noting as result for me ! :)
i have of course Nvidia ...
https://declanrussell.com/portfolio/nvidia-ai-denoiser/
yes ok...Created by Declan Russell (25/12/2017 ~ Merry Christmas!)
yes ok ...Input image: C:/Location of image to be denoised/noiseyImage.jpg
yes ok ...Loaded successfully
yes ok...Output image: C:/Location to save image/denoisedImage.jpg
nothing...Denoising…
nothing...Denoising complete
nothing...Saving to: C:/Location to save image/denoisedImage.jpg
nothing...Done!Voxel
Do you know an another cool one(s) free "Standalone" denoiser with the new AI technology?
This one but but it's not exactly a stand alone :)
... and alas this one following is mess to install (for me :)
https://github.com/DmitryUlyanov/deep-image-prior
EDITED: 20 Sep 2019 by PILOU
Not exactly the opopsite because without my glass i had believed that was moi3D ! :)
The shapr3D program looks interesting.
Todays email mentioned TikZ. Update as of September 2019.
The new manual is a mere 1244 pages.
So far, no opinion on this program:-)
From Moi to the free Twinmotion in using the new interface by Wayne! ;)
here _sSplit _SBridge _Subdiv9
Inset
EDITED: 15 Oct 2019 by PILOU
Careful when you import Moi Object inside Twinmotion Scale is generally necessary
as you have several colors as material you must careful to selected all colors for scale the entiere object!
Else you can imagine that something don't works!
EDITED: 16 Oct 2019 by PILOU
Show messages:  1-20  …  681-700  701-720  721-740  741-760  761-780  781-800  801-820  …  3101-3119
