 1-13  …  694-713  714-733  734-753  754-773  774-793  …  3114-3119
Message 4446.734 deleted 9 Jul 2019 by STARGAZER
De-Lighter
free stand-alone tool designed to remove shadows from model textures.
The tool is targeted on removing cast shadows and ambient occlusion from 3D models.
It requires user input in a form of rough brush strokes marking lit and shadowed areas.
https://www.agisoft.com/index.php?id=71
Terrific! Transform your videos in your favorite styles at each keyframes! Free!
https://ebsynth.com/
4446.737 In reply to 4446.736
Impessive !
Hello everyone!
Version 4.9 beta of 3D-Coat released.
New amazing tools!!!
Many of them are still in beta but it's a very promising update :)
https://3dcoat.com/v4.9/
4446.740 In reply to 4446.739
Thanks Marco,
How does 3DCoat work with MoI3D?
Is zbrush better?
I see it is $100 off for a few days.
I think it depends on your use case. If you are an Industry
Professional people go with ZBrush. If you are a hobbyist
people go with 3DCoat.
I have both and I love Zbrush much much more than 3DCoat.
The brushes in ZBrush are more fluid and ZBrush can handle
on small machines much more geo than 3DCoat.
The only thing were 3DCoat is better is in it's
PBR painting tool set and image to mesh functionallity.
And last but not least, 3DCoat is in permanent beta state ...
So always little bugs which will be fixed in the next beta and
so on.
EDITED: 27 Jul 2019 by STEFAN
4446.742 In reply to 4446.740
Hello Brian!
3DC is overall a great choice!
If you have a capable machine (with good CPU/GPU) it can offer a very powerful environment with tons of tools.
Maybe it's UI can be still a little messy in some aspects and, as said by Stefan, some of its powerful tools are still in beta, but its PBR Painting Room and its Voxels and also other tools are amazing.
As said by Stefan "...If you are an Industry Professional people go with ZBrush.".
This is actually true.
But the second part of the phrase "...If you are a hobbyist people go with 3DCoat"
I don't know how or where Stefan took this idea, but many many professional artists and designers, especially for game industry, uses 3DC daily into their pipelines with GREAT results.
It depends on what you have to do, but at that price tag, 3DC is a cornucopia of very powerful tools!
Hi Marco,
sorry, I meant more the price tag, which is affordable for hobbyist,
compared to the price tag of ZBrush. And yes, it is true about
Game Industry Professionals, which I forgot to mention, because
I have no overview of the Gaming World, sorry!
4446.744 In reply to 4446.743
No problem Stefan! :)
I only wanted (hoped) to give a more complete view over 3DC.
Both ZB and 3DC are amazing tools!
ZB is super powerful but also it has a steeper learning curve.
Thankyou Stefan and Marco.
There is a little difference for 3D Coat: you can modelize entierely from "Voxel" (microscopic cubes)
and at the end transform in classical OBJ polygonal format.
ZBrush has not this function (only hidden for the user for few functions (Unify Skin, ShadowBox...)
And modelise by ZBrush "Shadow Box" Plane by Plane is not the same than 3dCoat
Another difference : 3D Coat has a classical Interface! ;)
EDITED: 27 Jul 2019 by PILOU
4446.748
https://cables.gl/home
Cables is a visual programming environment to create interactive content for the web.
Another "Node" fetish :-)
4446.749 In reply to 4446.748
Seems very cool indeed! (Elephant on steroîds :)
EDITED: 21 Aug 2019 by PILOU
4446.750
The Blender 2.81 master builds now include Intel's AI-powered Open Image Denoiser (OIDN). It's quite impressive what it can already do with a one-sample rendering:
https://twitter.com/simonthommes/status/1164202286027030529
Have a nice weekend,
Metin
Freelance visualizer • illustrator • animator • 3D designer — metinseven.nl
Crazzy! (move with your mouse for amplify the "rotations" :)
https://cables.gl/p/lipIpP
EDITED: 29 Aug 2019 by PILOU
Not opposite because it's only Moi Objects! :)
Just for validate a cool flow of modeling! Only Blending surfaces in 5 seconds! :) (time to select curvated edges)
Cut the result in 2 parts - Shell - (here twice the same from 2 different views)
EDITED: 3 Sep 2019 by PILOU
MagicaVoxel comes back with the Intel Denoiser integrated! ;)
Intel Open Image Denoiser [0.99.4.2]
Requirement: 64bit system, 4GB memory
Installation: download plugin.zip and extract the content to the program folder. (menu Win64 or MacOs plugin) https://ephtracy.github.io
Image->Filter->Denoise: denoise rendered images in the preview mode. use mouse wheel to zoom in/out, left-drag to move image.
Image->MRT: render additional albedo and normal images to help the denoiser to preserve details. note that it does not always improve the quality.
Sample->Bounce->Clamp: clamp energy to reduce noises.
Image based Lighting [0.99.4.1]
Sky->IBL: Image Based Lighting. use ".hdr" format panorama images to light the scene.
Fog: add Equi-angular sampling back to reduce noises. support fogs in othogonal views in a bounding volume.
Media: enable Sample->TR-Shadow to allow single direct lighting; enable Sample->MIS-Cloud to allow multiple direct lighting (very expensive).
Color all color options have their own color pickers which support HSV, RGB, H-Block and Hex values.
Palette Menu right click the palette view to show the pop-up menu.
https://twitter.com/i/status/1169292160400875526
Show messages:  1-13  …  674-693  694-713  714-733  734-753  754-773  774-793  794-813  …  3114-3119
