 1-10  …  591-610  611-630  631-650  651-670  671-690  …  3111-3119
With a little piece of the above image and a triple loops of Processing :)
I believe that you can change anything you want aespecially t between 1 - 50, the coef of k 1 - 5 etc...
Tell me if that work for you in direct on the fly ! Press the black triangle inside the yellow disc!
Then change the code...
A cool thing that this Web Editor!
https://editor.p5js.org/Pilou/sketches/PE_HwNoXH
EDITED: 12 Feb 2019 by PILOU
4446.632 In reply to 4446.631
Interesting...
@You : "...Tell me if that work for you..."
Yes! It works :)
4446.633 In reply to 4446.632
Cool! :)
Else a meta animation because the start image is the image above! :)
EDITED: 11 Feb 2019 by PILOU
Test compression...
A meta thing because it's the 72 images of an animation posted last week! :)
A possible fixed image
A close-up somewhere...walking is infinited! :)
brother...! :)
EDITED: 14 Feb 2019 by PILOU
4446.636 In reply to 4446.635
I like especially the penultimate images.
Looks like stones.
Beautiful!
In SketchUp Make 2017 (free)
Blue balls...
https://quadspinner.com/Gaea
Limited in 1K render for free but result can be used commercially!
EDITED: 27 Feb 2019 by PILOU
Magic!
4446.641 In reply to 4446.640
Wonderful!!
Thanks!
Nostalgia :)
A funny thing in what I participated with a friend ten years ago! ;)
https://www.mindomo.com/fr/mindmap/logiciels-3d-9b90f007d13a9a2a1b83e298627d1574
You can Zoom, Move etc...and click on the final arborescence for details :)
Not sure that Moi was yet present...Yes it was!!! :)
Mindomo in free has 3 maps possible! ;)
A cool concept! https://www.mindomo.com
Maybe I will remake one for free progs! :)
EDITED: 28 Feb 2019 by PILOU
Excellent!
Na ja, ... results looks average. I can do that much better with GEEX (from Bruno Levy, France), Houdini or other tools and MoI. ;-)
EDITED: 1 Mar 2019 by STEFAN
4446.645 In reply to 4446.644
Don't know Geex :) Not very images on the site!
https://gforge.inria.fr/projects/geex/
The source code for GEEX (Windows) is no longer available ...
All places which hosted the source code have it also no longer!
Here you can see a picture from one of the programs from GEEX:
(3rd posting from Torolf, showing the Batwing Surface.
https://www.sidefx.com/forum/topic/27610/lofi/
P.S my Voronoi Eggs are done, for example, with GEEX, Houdini and MoI too.
https://www.behance.net/gallery/34247989/Voronoi-Egg-CVT
It was an easy prog or not ?
And have you it always somewhere or it is an authorized prog ?
It was/is software for researchers, so you must know what to do and then use other
programs (like Houdini) to get the desired result. There are many steps involved,
so it would require a tutorial.
But since the program was taken of the Internet, it makes no sense to write
a tutorial, because i don't know if it is allowed to distribute the software ...
I think also it is no longer available, because professional Designers like
to use such software for free and then doing paid gigs with that and without
mentioning the author. This happens very often, unfortunately.
4446.650 In reply to 4446.649
No problem! ;)
There are some others over the world! :)
Show messages:  1-10  …  571-590  591-610  611-630  631-650  651-670  671-690  691-710  …  3111-3119
