 1-10  …  531-550  551-570  571-590  591-610  611-630  …  3111-3119
Hi Marco,
why not try your images with 3DCoat (image to mesh) imho much better
(for such large files) than Magica. And you can use with 3DCoat more
than 256 colors ...
4446.572 In reply to 4446.570
I will take these above because I doubt that the big size will works! (but i will test also the big ones...;)
4446.573 In reply to 4446.572
@You: "...I doubt that the big size will works!!"
Maybe you can scale them down to the size you need.
Clearly you will lose details but for this kind of works I think it doesn't matter.
4446.574 In reply to 4446.571
Hi Stefan.
Thanks a lot for the tip :)
Much appreciated.
One day I will try it ;)
Actually I temporarily abandoned almost all 3D strictly related stuff and in my spare free time I'm digging into free hand 2D digital painting.
But thanks anyway for your suggestion!
Ok works ;) (recall me "crop circles" ;)
(images are 960 * 800)
Inside with cubes = Spheres
4446.576 In reply to 4446.575
WONDERFUL!!!
Very beautiful :)
Thank you so much!!
Very eye catching the second one but I didn't understand from which part of the original image is...
Could you upload also the generated .vox files?
Thanks a lot again.
So...some of my digital paintings could be useful to generate some fancy Magica stuff...
Good to know :)
Reload big size is not reasonnable! :)
No problem for the vox ;)
I unzip and post here ;) something like 75 & 137 megas zipped
Here the first : http://moiscript.weebly.com/uploads/3/9/3/8/3938813/string_theory.zip
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/space_lollipop.zip
I try you big images but i don't see well the interest (except freeze the latop! :)
EDITED: 24 Jan 2019 by PILOU
4446.579 In reply to 4446.578
THANK YOU SO MUCH!! :)
The second pictures from "Space Lollipop" is amazing!
Thanks also for the .vox file Maybe one of these days I will play with it ;)
Much appreciated.
4446.580 In reply to 4446.578
Thanks again :)
Very interesting elaboration!
4446.581 In reply to 4446.579
A little trick : when you render such number of matrices
you must enable a button "SV" under Render Menu / Show Sampling Setting / Geometry else image will be truncated!
(Image can also truncated if number of Matricices is too big!
Ps Can I post some of my render(s) of your image(s) in another places ? (with authoring of course)
Ok I try : message "Image is too big"! So no freeze... ;)
I will search the maximum ;)
Ok maxi for your image is 1500 * 1224 ( I take 1500 maybe a little more but not many more :)
SO here 12 * 9 = 108 matricices 126 *126 *126 = 216 040 608 voxels! ;)
4446.583 In reply to 4446.581
Thanks a lot for all the tech infos :)
Much appreciated again!
@You: "...Ps Can I post some of my render(s) of your image(s) in another places ? (with authoring of course)..."
I'm sorry.
No, for the moment I only want my original paintings on my Procreate profile and here on this forum (your elaboration of my images).
Thanks a lot for asking me. Very honest!
Thanks!
4446.584 In reply to 4446.583
No problem! :)
As I made one by day (minimum) i have enough! ;)
Some frightening to think that person is not real!
Message 4446.586 deleted 24 Jan 2019 by MKDM
4446.587 In reply to 4446.584
Thanks Pilou.
Clearly, if you want, feel free to play again with my previous two images in order to generate some other cool shots in Magica for this forum!
One question regarding all the tehc infos and knowledge that you have learned, with a very tough work I guess, about Magixa Voxel and how to create this kind of 3D render.
Are this info available putted all together in a some ordered way, maybe on your Moi's French site?
I hope so.
It could be very helpful to anyone who wanted to play with this kind of things, without the need to "reinvent the wheel" :)
Thanks.
4446.588 In reply to 4446.587
Of course all is yet on my French page! ;) (in French of course! ;)
http://moiscript.weebly.com/magicavoxel.html
4446.589 In reply to 4446.588
Perfect!! Thanks a lot.
No problem for French, I will use a translator to english :)
Did you include in that page also the new trick yo told me in the other post?
@You: "A little trick : when you render such number of matrices
(Image can also truncated if number of Matricices is too big!"
It's very important I think...
4446.590 In reply to 4446.589
Existing! ;)
Show messages:  1-10  …  511-530  531-550  551-570  571-590  591-610  611-630  631-650  …  3111-3119
