 1-3  …  524-543  544-563  564-583  584-603  604-623  …  3104-3119
4446.564 In reply to 4446.562
Hi PIlou!
Thanks a lot for your willingness!
And thanks a lot for your quick resume and short tutorial as well!
@You : "But why you don't try to make that with Magica ? i have yet took all for that!"
I'm sorry, but as I said, for the moment I don't have enough extra free time to devote to playing with these things, and actually you're certainly better than me and more skilled to create easily some cool stuff with Magica.
So, I'm going to send you a PM with two of my digital paintings.
I don't know if they're good for the conversion into a Magica's world.
Anyway, you will find a good way to use them into Magica.
Thanks a lot :)
4446.565 In reply to 4446.562
Hi Pilou.
I tried to send you mi images via a PM but I get this error while sending:
"The following errors were encountered:
PILOU has opted out of receiving personal messages"
4446.566 In reply to 4446.565
Curious because I receive some PM all days! :) (my PM box is not 100% full )
Try by email if you have always this PM alert message!
4446.567 In reply to 4446.565
Hi Marco,
Maybe it's a bug in the error message - Marco, have you possibly disabled PM messages in your own settings? That's under forum Options > "Email & Privacy" > "Email and contact settings" > "Allow other users to send me personal messages".
Maybe if you have that disabled you won't be able to send a PM either.
4446.568 In reply to 4446.567
Hi Michael.
@You: "...Maybe if you have that disabled you won't be able to send a PM either..."
Thanks for the tip :)
But I tried to search the options to enable PM again but I don't remember where it is.
Where is it?
4446.569 In reply to 4446.567
Found it :)
I'm sorry, I read the previous message too fast ;)
4446.570 In reply to 4446.566
Hi Pilou.
No problem with PM. I decided to keep it off.
I share here my two digital paintings that I did in Procreate (on iPad Pro).
If you want, play with them to create something fancy with Magica and share the results here on the Moi's forum :)
Both images are 5464 x 4096 pixels, so pretty big.
Image 1, called "String Theory" (in homage to one of the current theory of theoretical physics)
Original file to download: https://monosnap.com/file/LJ4lKcRVtXPb2te5BqKHyqJ0uz4Jab
Preview in low res:
Image 2, called "Space Lollipop"
Original file to download: https://monosnap.com/file/NAZHprIvWBc1w2gIXIJH7FrpvVtvz2
Preview in low res:
Thanks a lot!!
Hi Marco,
why not try your images with 3DCoat (image to mesh) imho much better
(for such large files) than Magica. And you can use with 3DCoat more
than 256 colors ...
4446.572 In reply to 4446.570
I will take these above because I doubt that the big size will works! (but i will test also the big ones...;)
4446.573 In reply to 4446.572
@You: "...I doubt that the big size will works!!"
Maybe you can scale them down to the size you need.
Clearly you will lose details but for this kind of works I think it doesn't matter.
4446.574 In reply to 4446.571
Hi Stefan.
Thanks a lot for the tip :)
Much appreciated.
One day I will try it ;)
Actually I temporarily abandoned almost all 3D strictly related stuff and in my spare free time I'm digging into free hand 2D digital painting.
But thanks anyway for your suggestion!
Ok works ;) (recall me "crop circles" ;)
(images are 960 * 800)
Inside with cubes = Spheres
4446.576 In reply to 4446.575
WONDERFUL!!!
Very beautiful :)
Thank you so much!!
Very eye catching the second one but I didn't understand from which part of the original image is...
Could you upload also the generated .vox files?
Thanks a lot again.
So...some of my digital paintings could be useful to generate some fancy Magica stuff...
Good to know :)
Reload big size is not reasonnable! :)
No problem for the vox ;)
I unzip and post here ;) something like 75 & 137 megas zipped
Here the first : http://moiscript.weebly.com/uploads/3/9/3/8/3938813/string_theory.zip
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/space_lollipop.zip
I try you big images but i don't see well the interest (except freeze the latop! :)
EDITED: 24 Jan 2019 by PILOU
4446.579 In reply to 4446.578
THANK YOU SO MUCH!! :)
The second pictures from "Space Lollipop" is amazing!
Thanks also for the .vox file Maybe one of these days I will play with it ;)
Much appreciated.
4446.580 In reply to 4446.578
Thanks again :)
Very interesting elaboration!
4446.581 In reply to 4446.579
A little trick : when you render such number of matrices
you must enable a button "SV" under Render Menu / Show Sampling Setting / Geometry else image will be truncated!
(Image can also truncated if number of Matricices is too big!
Ps Can I post some of my render(s) of your image(s) in another places ? (with authoring of course)
Ok I try : message "Image is too big"! So no freeze... ;)
I will search the maximum ;)
Ok maxi for your image is 1500 * 1224 ( I take 1500 maybe a little more but not many more :)
SO here 12 * 9 = 108 matricices 126 *126 *126 = 216 040 608 voxels! ;)
4446.583 In reply to 4446.581
Thanks a lot for all the tech infos :)
Much appreciated again!
@You: "...Ps Can I post some of my render(s) of your image(s) in another places ? (with authoring of course)..."
I'm sorry.
No, for the moment I only want my original paintings on my Procreate profile and here on this forum (your elaboration of my images).
Thanks a lot for asking me. Very honest!
Thanks!
Show messages:  1-3  …  504-523  524-543  544-563  564-583  584-603  604-623  624-643  …  3104-3119
