 1-3  …  504-523  524-543  544-563  564-583  584-603  …  3104-3119
4446.544 In reply to 4446.543
Really!
So, MagicaVoxel is a fun!
4446.546 In reply to 4446.545
Beautiful!
Why don't you try a different camera angle?
It could be very interesting.
Something like a little bit exaggerated field of view with the camera a very close to a section of the object and the rest of the scene blurred.
I don't know if i made myself clear :)
4446.547 In reply to 4446.546
Message 4446.548 deleted 18 Jan 2019 by MKDM
4446.549 In reply to 4446.547
@You "here the file. vox play with it! :)"
Thanks a lot!
But actually I don't have enough extra free time to devote to this :)
Looking forward to your new creations!
Thanks anyway.
New painting indeed! :)
Thx to Leonardo...& Zarbuz with it's SchematicToVox
and my little work! ;)
Inside Mona
EDITED: 18 Jan 2019 by PILOU
4446.551 In reply to 4446.550
4446.552 In reply to 4446.551
Always Mona! ;)
4446.553 In reply to 4446.533
Hi Pilou
can you tell me how you load an image inside MV.? I dindn't found any option.
Thanx
4446.554 In reply to 4446.553
@Apophis: --- You right : for the present version there is no importation Menu!
So
Current use for an OBJ object or an image PNG 256 colors
Just drag and drop your image or file.obj inside the screen of MagicaVoxel! ;)
That arrives in a "single" matrix ! (max 126 * 126 * 126 )
For a special use more advancedd you must use the Zarbuz plugin SchematicToVox : https://github.com/Zarbuz/SchematicToVox/releases
and use the Command Line of Windows
That permit to import more biggest result in several matrices in the same time! So super good!
For an obj file (with minimum parameters) you must first convert your file.obj in file.schematic
http://www.drububu.com/miscellaneous/voxelizer/index.html?out=vox or https://www.tinkercad.com/
then the Command Line (Logo Windows + R (in Windows 10) ( if images .png and .schematic file are present in the same folder than SchematicToVox.exe
for example
C:\Users\Pilou\Downloads\SchematicToVox-v1.3.1\SchematicToVox.exe --i objecta.schematic --o objecta (will gives you a file.vox)
For an image
C:\Users\Pilou\Downloads\SchematicToVox-v1.3.1\SchematicToVox.exe --i moni.png --o moni --hm 100 --color (will gives you a file.vox)
So at the end Open file .vox inside MagicaVoxel : can be a little long depending of files size!
EDITED: 20 Jan 2019 by PILOU
4446.555
Many Thanks :-)
Landscape for the pleasure of the eyes! (10 $)
https://pixelforest.itch.io/flowscape
Speed...
4446.558 In reply to 4446.557
Interesting... :)
From a cool French Painting! ;)
Le Rêve du Douanier Rousseau ... 1910...
Winter-Spring (with my image from DesignSpark Mechanical! ;)
EDITED: 23 Jan 2019 by PILOU
4446.561 In reply to 4446.560
Beautiful!!
Pilou I have a little request... :)
If you want, could you generate some of this renderings with Magica, using one of the painting that I've done in Procreate (on iPad)?
If you can do it, I will sent you a PM with one of my paintings and you can post here your Magica results :)
If you cannot, no problem :)
Let me know. Thanks.
4446.562 In reply to 4446.561
No problem it's 30 second for reload something...and you navigate as you want inside "your" image! ;)
Send me anything you want! :)
But why you don't try to make that with Magica ? i have yet took all for that!
I can make a little resume if you want! :)
MagicaVoxel installed
- Load somewhere the last version of SchematicToVox by Zarbuz : https://github.com/Zarbuz/SchematicToVox/releases
- put your image png 256 colors in the same folder (not obliged but more easy)
- Put the line following inside the command line of windows (Logo Window + R) (for Windows 10 without Pilou of course ;)
​C:\Users\Pilou\Downloads\SchematicToVox-v1.3.2\SchematicToVox.exe --i heightmap.png --o output --hm 100 --color an image
That all : an file output.vox is created : just reload it inside Magica and have fun exploration!
Ps for a Mac I prefere say nothing... because i don't know if the Schematictovox.exe works with this OS !
With an old image created with the incredible free Verve for valide that is writed above! :) (30 seconds all process)
White sun
Show messages:  1-3  …  484-503  504-523  524-543  544-563  564-583  584-603  604-623  …  3104-3119
