 1-19  …  500-519  520-539  540-559  560-579  580-599  …  3100-3119
So sweet! :)
Thx to Zarbuz for its very cool Schematic To Vox!
https://github.com/Zarbuz/SchematicToVox/releases
With my previous flower! ;)
(56 matrix 126 * 126 * 126 here! )
you can of course use any "image.png" 256 colors! I don't want imagine the possibilities!
EDITED: 17 Jan 2019 by PILOU
4446.542 In reply to 4446.541
Bellissimo!!
New 3D with old 2D image!
Revival! ;)
Amazing is not it ? ;)
4446.544 In reply to 4446.543
Really!
So, MagicaVoxel is a fun!
4446.546 In reply to 4446.545
Beautiful!
Why don't you try a different camera angle?
It could be very interesting.
Something like a little bit exaggerated field of view with the camera a very close to a section of the object and the rest of the scene blurred.
I don't know if i made myself clear :)
4446.547 In reply to 4446.546
Message 4446.548 deleted 18 Jan 2019 by MKDM
4446.549 In reply to 4446.547
@You "here the file. vox play with it! :)"
Thanks a lot!
But actually I don't have enough extra free time to devote to this :)
Looking forward to your new creations!
Thanks anyway.
New painting indeed! :)
Thx to Leonardo...& Zarbuz with it's SchematicToVox
and my little work! ;)
Inside Mona
EDITED: 18 Jan 2019 by PILOU
4446.551 In reply to 4446.550
4446.552 In reply to 4446.551
Always Mona! ;)
4446.553 In reply to 4446.533
Hi Pilou
can you tell me how you load an image inside MV.? I dindn't found any option.
Thanx
4446.554 In reply to 4446.553
@Apophis: --- You right : for the present version there is no importation Menu!
So
Current use for an OBJ object or an image PNG 256 colors
Just drag and drop your image or file.obj inside the screen of MagicaVoxel! ;)
That arrives in a "single" matrix ! (max 126 * 126 * 126 )
For a special use more advancedd you must use the Zarbuz plugin SchematicToVox : https://github.com/Zarbuz/SchematicToVox/releases
and use the Command Line of Windows
That permit to import more biggest result in several matrices in the same time! So super good!
For an obj file (with minimum parameters) you must first convert your file.obj in file.schematic
http://www.drububu.com/miscellaneous/voxelizer/index.html?out=vox or https://www.tinkercad.com/
then the Command Line (Logo Windows + R (in Windows 10) ( if images .png and .schematic file are present in the same folder than SchematicToVox.exe
for example
C:\Users\Pilou\Downloads\SchematicToVox-v1.3.1\SchematicToVox.exe --i objecta.schematic --o objecta (will gives you a file.vox)
For an image
C:\Users\Pilou\Downloads\SchematicToVox-v1.3.1\SchematicToVox.exe --i moni.png --o moni --hm 100 --color (will gives you a file.vox)
So at the end Open file .vox inside MagicaVoxel : can be a little long depending of files size!
EDITED: 20 Jan 2019 by PILOU
4446.555
Many Thanks :-)
Landscape for the pleasure of the eyes! (10 $)
https://pixelforest.itch.io/flowscape
Speed...
4446.558 In reply to 4446.557
Interesting... :)
From a cool French Painting! ;)
Le RĂªve du Douanier Rousseau ... 1910...
Show messages:  1-19  …  480-499  500-519  520-539  540-559  560-579  580-599  600-619  …  3100-3119
