 1-11  12-31  32-51  52-71  72-91  92-111  …  3112-3117
4446.52 In reply to 4446.51
Thanks a lot Pilou for the info.
Very interesting the Goxel script language manual!
Is there an English version ? (I don't speak french...)
4446.53 In reply to 4446.52
4446.54 In reply to 4446.53
Thanks a lot :)
4446.55 In reply to 4446.53
Great info, thanks Frenchy
Do you ever sleep? ... seems like you are always coming up with new stuff.
4446.56 In reply to 4446.55
Some insomiac indeed! :)
Hi Pilou!
I don't remember if you have already reported this web app, but if not,
I think you'll find rather interesting these great 3d web app from Stéphane GINIER (https://stephaneginier.com/) :
https://stephaneginier.com/archive/editSDF/
https://stephaneginier.com/sculptgl/
See you!
Marco (mkdm)
4446.58 In reply to 4446.57
Excellent alternative to the free Sculptris http://pixologic.com/sculptris/
About the incredible online https://stephaneginier.com/archive/editSDF/
you must press the button "Apply" for validate a primitive before call a new one!
EDITED: 2 Jun 2017 by PILOU
4446.60 In reply to 4446.59
Hi Pilou!
Yes...I already know.
But I don't know how to export in obj format. it seems that it's available only a strange "glsl" (OpenGL) format,
and I don't know how to use it in order to import the geometry data into other software.
Do you know more ?
Marco (mkdm)
Hi Pilou and everyone.
WOOOOOOOWWWW !!
Found this : https://www.shadertoy.com/
I didn't know it. it can load "glsl" Pixel Shader file generated from "https://stephaneginier.com/archive/editSDF/" !
From its About page : "Shadertoy is the first application to allow developers all over the globe to push pixels from code to screen using WebGL since 2009."
And from Stackoverflow :
"ShaderToy is a tool for writing pixel shaders."
Look at this : http://pixelshaders.com/
It seems to be very very interesting...
See you.
Marco (mkdm)
P.S. See this video article : https://www.youtube.com/watch?v=TDZMSozKZ20
EDITED: 2 Jun 2017 by MKDM
Hi Pilou.
Look also at this! It's awesome on my 1080 Ti : https://www.shadertoy.com/view/llK3Dy
Ciao!
About the json format :)
there are some converters on line http://codebeautify.org/jsonviewer
alas the xlm resulting can't be reloaded inside Kerkythea (the only one for the moment that I remember that reload xlm file! :)
I believe that with Processing (a free coding program, you can reload json file format with some library installed and save as obj)
but i want find more simple! :)
In any case json format is reloaded by the editSDF itself!
4446.65 In reply to 4446.63
Shadertoy
Sure sound + crazy images & shaders that is hyper cool!
(but seems little codes must be done ? ;)
Minutes 1.06- 1.26 of your link!
4446.66 In reply to 4446.65
Ah ah ah....very funny this one. Look : https://www.shadertoy.com/view/XsBXWt
All in realtime on GPU!
@You : "...but seems little codes must be done ?..."
Oh yeah!! A lot of code.
But I totally don't know that programming language and math or OpenGL shaders aren't in my programming kwnoledge :)
(I write business app for android/ios)
It's only funny for me to watch how these guys are able to push out from GPU :)
See you.
4446.67 In reply to 4446.65
Oh my God! I can't stop watching that stuff!!
Pilou, look at this insane and amazing realtime video : https://www.shadertoy.com/view/4dlyWX
Amazing!!!
OK. Over and out!
Ciao.
I believe that Unity can import json file! ;)
Alas I must reload unity for test that because the new update of Windows 10 invalidate my previous licence!
Relaoded but...
Not trivial for json, xml, so...good luck! :)
4446.69 In reply to 4446.68
But...what about Unreal Engine and Json ?
I'm trying to use UE instead Unity....
4446.70 In reply to 4446.69
Must be possible as like! ;)
Else with SDF :)
4446.71 In reply to 4446.69
@Marco
http://www.mediafire.com/file/0oynrpi11opvkm7/OBJ+and+JSON+Converter+Program+2.0.zip
Features:
* Drag and drop support on executable.
* Easy to use program.
* Converts OBJ to JSON
* Converts (converted)JSON to OBJ
Recommended:
Windows 2000, XP, Vista, Win7
Alas for me during the convert "the Convertor has stopped to work" ... (surelly because I have Windows 10! :(
So a convertor on line (if existing) will be the solution!
EDITED: 3 Jun 2017 by PILOU
Show messages:  1-11  12-31  32-51  52-71  72-91  92-111  112-131  …  3112-3117
