 1  …  342-361  362-381  382-401  402-421  422-441  …  3082-3094
4446.382 In reply to 4446.381
>>Very bad ?
it was the exact reflect of the original picture! :)
I believe that you can import a palett with colors of your original image!
the original is only126*126! ;)
EDITED: 6 Sep 2018 by PILOU
yes, very bad, IMHO, because when i used a photo and made a small
picture it had false colors and only a few of them, after importing to
MagicalVoxel. But like you said, maybe there is an option for the
correct color palette import, which i have not found yet.
4446.384 In reply to 4446.383
you right if the max is 255 colors that is some limited!
Maybe we must import the palett of the image made specially for it!
Else it's palett work is funny! Shift + Alt from a color to another on a platell makes a gradient : by line or by diagonal!
4446.385 In reply to 4446.377
Hi Fabien,
I fully understand your viewpoint, and the non-destructive workflow in C4D is definitely interesting.
Regards,
— Metin
visualization • illustration • animation • 3D design — metinseven.nl
i figured out how to get correct colors from my previous image, in MagicaVoxel! :-)
Simply first drag and drop the image on the color palette, so that the color palette gets the
colors from your image and then drag and drop your image again in the voxel room. Not
hundert percent correct, because of 256 colors limit, but very good result for MagicaVoxel.
Bildschirmfoto_2018-09-06_um_16.16.30
4446.387 In reply to 4446.386
@Stefan
One more time that is magic and so simple!
I have find that i must make a little programm in Processing for make a PNG 256*1 from a palette given by a 2D Prog!
My neurons say thank you!
So many Thanks! :)
You're welcome, Pilou!
But i don't understand why you must make a little Processing program...
4446.389 In reply to 4446.388
@Stefan
Because I did't know the trick of drag&Drop image on the Palette!!!
Now no need to make the plugin! :)
Ah..., o.k. now i understand! :-)
4446.391 In reply to 4446.390
It's not so bad! :)
In any case a very good trick! Bravo!
EDITED: 8 Sep 2018 by PILOU
Looking good, Pilou! :-)
Maybe it depends on the colors and voxel size used, but yours looks fine.
4446.393 In reply to 4446.392
Do you know a trimer image who create some files automatically
say i have an image 500*500 pixels
result wished will be this and of course in PNG
Max of 126*126 wished first
I have a normal Slicer, i search an "optimisation slicer" !
I have seen that for filling containers's boat, truck, cloth triming, wood, filling package... must be existing for image :)
EDITED: 7 Sep 2018 by PILOU
Well, Photoshop can do this with it's "slice" tool and then you can save all
created slices at once, to have all the sliced pictures in one folder.
4446.395 In reply to 4446.394
I have seen that for filling containers' boat, truck, cloth triming, wood, filling package... must be existing for image :)
GIMP has also a Guillotine function, but i don't know if you can slice the same way
like Photoshop, which would allow you to do exactly what you are looking for.
4446.397 In reply to 4446.396
Looks like that this slicer has also variable slices options...
https://www.cyotek.com/cyotek-slicr
4446.398 In reply to 4446.397
Thx
the generic term is the "Bin Packing" for automatic optimisation of slicing...storage...
Here in 3D and in French but very visual for SketchUp ;) (English SubTitles possible)
Modeling MagicaVoxel ;)
By Sir_carma https://twitter.com/Sir_carma
Completly astonishining!
My Moi French Site My Gallery
4446.401 In reply to 4446.400
Wonderful! MagicaVoxel is a superb tool!!
Show messages:  1  …  322-341  342-361  362-381  382-401  402-421  422-441  442-461  …  3082-3094
