 1-11  …  332-351  352-371  372-391  392-411  412-431  …  3112-3117
Thank you Metin, for the detailed explanation!
I like MagicaVoxel too, after exploring it's feature set and like also it's modeling
environment. The only thing i dislike is it's mesh export (no nice quads), but
for this i found my solution. Texture support for import would be also a nice
feuture to have, but for a free app i can't complain... ;-)
4446.373 In reply to 4446.371
Goxel looks interesting, thanks Pilou.
Regards,
— Metin
visualization • illustration • animation • 3D design — metinseven.nl
4446.374 In reply to 4446.372
My pleasure, Stefan. I agree, MagicaVoxel is the star of the voxel show at the moment.
Regards,
— Metin
4446.375
Hi all,
Since we're talking about voxels here frequently - did anyone check out Cinema 4D's Volume modeling system (based on OpenVDB) yet?
From playing with the R20 demo version a bit and looking into a lot of intro videos, it actually seems to be an extremely powerful and versatile tool. Likely a game-changer for a lot of organic modeling tasks.
I presume this is very much like the MOP Booleans Kit for MODO, though I am not exactly sure. 3DCoat has voxels at it's core too, but afaik, they are not working in a non-destructive fashion - which is what makes it so powerful in C4D. Almost anything that generates geometry (including splines, particles, even shaders) can be used and combined (in boolean fashion) which is quite an amazing feat.
Here are some interesting links:
https://www.youtube.com/watch?v=xR2Uozqcd0M
https://www.cineversity.com/vidplaylist/volume_3_siggraph_2018_rewind
https://twitter.com/i/status/1034485610193608705
- Fabien
4446.376 In reply to 4446.375
Hi Fabien,
Thanks for the links. C4D's OpenVDB volume modeling looks very useful, but except for the interesting non-destructive approach I see nothing that wasn't already possible using ZBrush and/or 3D-Coat, both of which are also based on voxels.
ZBrush offers Live Booleans, which also offer you to manipulate Boolean sub-objects in realtime until you're satisfied. And you can smoothly melt everything together using Dynamesh or Boolean + Tessimate.
The C4D screwdriver creation video reminds me of the recent Project Primitive deformer addition in ZBrush 2018. A really powerful tool once you get the hang of it:
In Blender you can mimic OpenVDB's type of combining and melting together meshes using Dyntopo in Sculpt Mode.
There's also a free OpenVDB Blender add-on offering the functionality to Blender users (too bad there's no version for Blender macOS yet):
https://blenderartists.org/t/addon-openvdb-remesh/1102023
What I miss in both Blender and C4D is an advanced auto-retopology tool like Zbrush ZRemesher or 3D-Coat Autopo, following the flow of an object with clean, all-quad topology, suitable for subdivision.
Regards,
Metin
visualization • pixel art • illustration • animation • 3D design — https://metinseven.nl
EDITED: 5 Sep 2018 by METINSEVEN
4446.377
Hi Metin,
Thanks for chiming in. I can see that if you are more into purely organic modeling and perhaps character design and sculpting, zBrush and 3DCoat will be much better.
As for me though, I feel much more comfortable having parametric objects and complete non-destructive tools at my disposal.
I'm a (product) designer, so being able to tweak a concept easily and almost infinitely makes a lot of sense, especially since you can throw in some primitives and other elements that are more less well defined (in a numeric/technical) way. You have a lot of control in C4D, and most parameters take actual measurement values. Not to mention non-destructive falloff objects (called 'fields' in R20) for even more control.
I guess it all depends on your mindset. Although I have both zBrush and 3DCoat, I never really enjoyed working in them - I find the sheer amount of tools and panels in both apps a bit overwhelming to be honest. It's why I prefer MoI to Rhino, which I happen to own as well.
I'm going to test C4D some more. I've used it quite extensively some 15+ years ago, but never really touched much thereafter, and used Modo for (mostly) rendering instead. R20 has some compelling features though, so I'm reconsidering adding it to my toolbox again.
- Fabien
Pixolator is always the genious artist creator of ZBrush! :)
My Moi French Site My Gallery
... and a little portrait test. :-)
4446.380 In reply to 4446.379
<<< Texture support for import would be also a nice
@Stefan
Hello
In Magica Voxel you can Import an Image PNG 126*126 in Edit Mode so 126*126*1 inside MagicaVoxel
(only Drag&Drop : menu Import don't yet existing)
increase after import the general matrix following that you want
Larger scene area: (-1024, +1024)
Maximum matrix is : 512x512x512, 1024x512x256 or 1024x1024x128
As you can make one Multiple Drag&Drop image(s) you can have the same than above! ;)
Just find something who trim your original image in step 126*126 pixels on some png files ;)
After import image you can of course make some landform with some extrude following matrix aceptable
The OBJ export will report all this! ;)
Here after some extrude and increased the 126*126*1 matrix
EDITED: 6 Sep 2018 by PILOU
i'm aware of picture import, but as you can see in your example
the color palette in MagicaVoxel is very bad...
I was also refering to .obj import with color textures, which i have
not seen yet in MagicaVoxel.
4446.382 In reply to 4446.381
>>Very bad ?
it was the exact reflect of the original picture! :)
I believe that you can import a palett with colors of your original image!
the original is only126*126! ;)
yes, very bad, IMHO, because when i used a photo and made a small
picture it had false colors and only a few of them, after importing to
MagicalVoxel. But like you said, maybe there is an option for the
correct color palette import, which i have not found yet.
4446.384 In reply to 4446.383
you right if the max is 255 colors that is some limited!
Maybe we must import the palett of the image made specially for it!
Else it's palett work is funny! Shift + Alt from a color to another on a platell makes a gradient : by line or by diagonal!
4446.385 In reply to 4446.377
Hi Fabien,
I fully understand your viewpoint, and the non-destructive workflow in C4D is definitely interesting.
Regards,
— Metin
i figured out how to get correct colors from my previous image, in MagicaVoxel! :-)
Simply first drag and drop the image on the color palette, so that the color palette gets the
colors from your image and then drag and drop your image again in the voxel room. Not
hundert percent correct, because of 256 colors limit, but very good result for MagicaVoxel.
Bildschirmfoto_2018-09-06_um_16.16.30
4446.387 In reply to 4446.386
@Stefan
One more time that is magic and so simple!
I have find that i must make a little programm in Processing for make a PNG 256*1 from a palette given by a 2D Prog!
My neurons say thank you!
So many Thanks! :)
You're welcome, Pilou!
But i don't understand why you must make a little Processing program...
4446.389 In reply to 4446.388
@Stefan
Because I did't know the trick of drag&Drop image on the Palette!!!
Now no need to make the plugin! :)
Ah..., o.k. now i understand! :-)
4446.391 In reply to 4446.390
It's not so bad! :)
In any case a very good trick! Bravo!
EDITED: 8 Sep 2018 by PILOU
Show messages:  1-11  …  312-331  332-351  352-371  372-391  392-411  412-431  432-451  …  3112-3117
