 1-5  …  306-325  326-345  346-365  366-385  386-405  …  3106-3119
4446.346 In reply to 4446.345
Yes, I almost forgot. You can simply use the Remesh modifier in Blender as well. :)
Regards,
— Metin
visualization • illustration • animation • 3D design — metinseven.nl
Seems OBJ format Magica Voxel keep color painted inside at the exportation
but these colors are not affectable separatly in a render Engine!
here the file created at the exportation without background obj +mlt+png (of Magica Palett colors - not background)
must create a file with separated colors - for address some different materials : any idea ?
I miss some inspiration now! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/bul.zip
here inside SimLab
EDITED: 1 Sep 2018 by PILOU
Hi Metin,
thanks for the tip with ZBrush. I just converted the dog asset and do with it something in MoI.
It takes a while until it is finished, but i hope the end result will look nice.
Hi all,
here is something funny... The first time i use the word penis, in combination with 3D. The penis
gives me non-manifold geometry in my dog model, which i'm currently working on. So i have
to make a female dog... :-D
Bildschirmfoto_2018-09-02_um_12.15.09
photo hosting
4446.350 In reply to 4446.349
Very conceptual! :)
My Moi French Site My Gallery
Thank you Pilou! :-)
and here is the final model. Renderings will follow on a later date.
Bildschirmfoto_2018-09-02_um_17.27.33
...and a rendering. Hope you like!
4446.353 In reply to 4446.352
Remember animal wood building!
(here mechanical)
For the little story : all the animation, modeling etc is made with ArchiCad + GDL language! (not by me! )
EDITED: 2 Sep 2018 by PILOU
4446.354 In reply to 4446.352
Very nice Stefan! Very nice :)
Any idea for transform this single obj with different materials/colors in different objects by same material/color ?
I was unlucky till now! (detailled workflow needed...)
Thx by advance!
I tought that just some explode, select by colors will be fine but...
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/bul.zip (without wavy background)
About problem above
Edit: resolved : I can make that with the last version of MagicaVoxel before export! :) 0.99.1
make different group by selected colors but maybe I spoke too quickly! :)
PS Seems Last version of Magica has no more Import OBJ : so keep the 0.98 ;)
EDITED: 4 Sep 2018 by PILOU
Thank you Marco, much appreciated!
Deep Learning for images * 600 % (99$)
Impossible to make more neat!
https://topazlabs.com/ai-gigapixel/
i just purchased the IMHO awesome Cubik Studio...which allows you to do that
with different materials for colors... As you can see in my picture i exported
a divided sphere from MoI with different styles and then run it through Cubik
Studio. You then have separate objects, which you can then give a different
material in SimLab Composer, i strongly assume.You can also import textured
.obj into Cubik Studio!!!! :-)
P.S. these are then Vertex Colors... I hope SimLab Composer can import and
show vertex colors!
P.P.S. sorry, Pilou it also divides when using complex models in different
areas with more colors, so you need a Polygon Modeler, which a. can
import Vertex Colors and b. then you have to join/seprate the polygons
where the colors are, to get different materials...
It cost only under 20 € and is IMHO well worth it.
Cubik_Studio
image host
EDITED: 4 Sep 2018 by STEFAN
4446.360 In reply to 4446.359
Interesting, Stefan. Is Cubik Studio a MagicaVoxel / Qubicle competitor? I'll Google it and have a look.
Regards,
— Metin
Thx for the efforts!
for the moment i have made hundred of tests! (with programs I have) in a tonne of format! OBJ, DAE, PLY, 3DS
Meshmixer, MeshLab, Wings3D, Blender, SketchUp, pConPlanner and the Voxel Magica, Goxel
(i don't want use Zbrush or 3DCoat because I want a free solution ! ;)
Problem is that Magica produce objects in OBJ formats following that you have made
- one files where colors must be separated in Simlab (impossible easily for the moment)
or
- multiple files (when you make separated objects) who can't be reloaded mysteriously in simLab at the good place! (and manually one by one)
For the moment best is used SketchUp (.skp) - because arborescence of Objects/ colors are reloaded in one time inside Simlab!
but you must load one by one the objects inside SketchUP before export!
An another mystery is all formats dae, 3ds arrive without colors inside SketchUp!
so the Graal for this easy thing is not yet found! :)
Maybe I miss an option inside Magica for have a "group" of "objects" who can export in one time as group(s) for arrive as arborescence inside SimLab?...
Ps i have found a free Poly2Voxel here http://advsys.net/ken/download.htm! ;)
Right click on your OBJ file object / open with Poly2Voxel
A master Of Magica! It's really a magical program! ;)
4446.362
Hey, Cubik Studio stole two of my works for their homepage, without asking for permission (the man on the moon and the gamer on an island). I'm not happy about this and will contact them.
Regards,
— Metin
i understand, your task with Magica Voxel seems not be so easy. I for myself needed
a solution to have textured Voxels from .obj wich i can easily manipulate in Shade3D.
Later i can then bake textures from such a quad mesh for Maxwell Render.
Bildschirmfoto_2018-09-04_um_11.34.10_Kopie
schnell bilder hochladen
Hi Metin,
that is really not nice from them! Hope you get it sorted out!
Hi Metin,
i just checked out your beautiful Voxel works. Really nice images!
How long does it take to work on such images and what editor
have you used?
Best regards
4446.365 In reply to 4446.52
I have found a forum about Magica Voxel in French but here in English! ;)
https://discordapp.com/channels/260458461677092864/368348851796574220
and of course this blog! ;)
https://twitter.com/ephtracy
by John Kearney
Show messages:  1-5  …  286-305  306-325  326-345  346-365  366-385  386-405  406-425  …  3106-3119
