 1-9  …  290-309  310-329  330-349  350-369  370-389  …  3110-3117
Meshroom: Photogrammetry Open Source
https://alicevision.github.io/#meshroom
My Moi French Site My Gallery
before the direct Brain connection! :)
Manchu (Philippe Bouchet)
A big blog!
http://manchu-sf.blogspot.com/
a fan of Chris Foss of course! ;)
EDITED: 29 Aug 2018 by PILOU
Visions of the future (5 parts)
Hi Pilou and all,
maybe interesting for you... It is possible to load .obj meshes into MagicalVoxel,
when converting .obj to .off and then use these two converters* from here:
http://dgtal.org/doc/tools/nightly/converters.html#converters
first run the .off file through mesh2vol and then through vol2vox.
However, in order to use these converters you need to compile the DGtal
library and also the DGtalTools.
Bildschirmfoto_2018-09-01_um_01.25.45
4446.335 In reply to 4446.334
it's not more easy with Goxel?
http://guillaumechereau.github.io/goxel/
Magicavoxel-->Goxel
or even if you want only render you have the free Simlab Composer Lite (works with any 3D format files! :)
who has a Voxel function! :) (Maxi 1920*1040) (you can only save in proprietary format! )
EDITED: 31 Aug 2018 by PILOU
i don't know, can you import with Goxel .obj and export to MagicalVoxel?
4446.337 In reply to 4446.336
Seems yes for Magica Voxel :)
But I don't very well understand that you want to do in finality ?
EDITED: 1 Sep 2018 by PILOU
The idea is that you can take any .obj convert it and load into Magical Voxel,
so that you don't have to model it in there... :-) Or to simply voxelize and
color a converted .obj file.
4446.339 In reply to 4446.338
But you can import an OBJ File directly inside Magica Voxel!
I don't have this import button, hence that's why i wrote about the converters.
I downloaded version 0.99 and i can not see this in the Mac vers.... :-(
O.k. according to a Twitter post, i can drag and drop an .obj file or image
to the canvas, but the resolution is then for the .obj much smaller than
how i did it with the converters...
Mac users are always unlucky! :)
after direct import inside Magica Voxel (some speedy little paint for example and Cylinder as "modules" )
So the best worflow is import OBJ to Magica Voxel (very speedy) then use the Simlab Lite for a more elaborated rendering!
(because the Simlab Voxelisation directly (some posts above) is some painful - i discourage that! )
MeshMixer or Rocket3F MeshLab or your favorite 3D Package for the OBJ repair...
4446.344
I just thought to mention that ZBrush can also convert meshes to a voxelized representation.
Use Tool ➔ Subtool ➔ Remesh All, or Tool ➔ Unified Skin to voxelize meshes. Turn down Polish / Smooth to 0. Remesh All has more options, and creates a new subtool, while Unified Skin creates a new tool you have to activate.
Regards,
— Metin
visualization • illustration • animation • 3D design — metinseven.nl
4446.345 In reply to 4446.344
Yes but it's not the same price! :)
Blender is also a challenger! :)
4446.346 In reply to 4446.345
Yes, I almost forgot. You can simply use the Remesh modifier in Blender as well. :)
Regards,
— Metin
Seems OBJ format Magica Voxel keep color painted inside at the exportation
but these colors are not affectable separatly in a render Engine!
here the file created at the exportation without background obj +mlt+png (of Magica Palett colors - not background)
must create a file with separated colors - for address some different materials : any idea ?
I miss some inspiration now! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/bul.zip
here inside SimLab
Hi Metin,
thanks for the tip with ZBrush. I just converted the dog asset and do with it something in MoI.
It takes a while until it is finished, but i hope the end result will look nice.
Hi all,
here is something funny... The first time i use the word penis, in combination with 3D. The penis
gives me non-manifold geometry in my dog model, which i'm currently working on. So i have
to make a female dog... :-D
Bildschirmfoto_2018-09-02_um_12.15.09
photo hosting
Show messages:  1-9  …  270-289  290-309  310-329  330-349  350-369  370-389  390-409  …  3110-3117
