 1-20  …  3061-3080  3081-3100  3101-3119
4446.3101 In reply to 4446.3100
Yes the "opposite" as said in the thread tittle! :)
Cool i didn't known this Ai Cartoon Generator!
But seems it don't keep original model in Image to image!
Or does exist a trick ?
EDITED: 14 Apr 2025 by PILOU
Kling 2 but free version has not in free the new model of image! :(
My Moi French Site
Leonardo is incredible!
EDITED: 17 Apr 2025 by PILOU
Happy Easter Eggs! :)
My Moi French Site
40 Big Zoom Eggs : https://imgbox.com/g/t1Rp47UsBW
Vizcom Mix
My Moi French Site
Leonardo
36 big Zoom : https://imgbox.com/g/ePPEDVnkAp
My Moi French Site
OrigamiSimulator
Vizcom
My Moi French Site
4446.3108 In reply to 4446.3106
Where did all of those egg themed images originate?
Frederick
4446.3109 In reply to 4446.3108
@Fcwilt
Very easily! :)
I input this image (or similar) inside Leonardo! (will be another story for it self! ;)
Speedy Tuto
The Leonardo Section Image! (on the start online Application)
Legacy Mode (old Interface...check) / Image Guidance (check) (like Control Net on another prog)
Then load your source image above, and choose your image palette effect...here Image to Image
The Type "Control Net" image palette ...each one obviously gives a different result!
And, of course, your rendering engine (not-XL) and Element(s), if required, to achieve infinite profusion!
Here i used the cool "Isometric SFI Buildings"
And adjusting the cursor forces of all this junk... seems a little complicated... but once you've practiced a little, it works like a charm in 5 sesnonds!
In general, for a 780 x 780 size, it's 3 credits, for a 1040 x 1040 size it's 4 credits
All this over 150 automatic daily credits... and it's great, it keeps all the generations in memory!
You can run 10 generations in a row and watch their output on "Generation History"
I have used only 2 ELements ... Inferno & Baroque (Alone or both)
General tuto! :)
EDITED: 22 Apr 2025 by PILOU
For the first original image itself... free Gemini 2.5 experimental (imagen 3)
with the prompt
"a very complex colored transpararent engine Easter Eggs on Mars"
And if you want infinite variations of it...
Use the free Vizcom! with any images you want...:)
Use the Mix function...press generate any time you want...
nothing to do, no prompt, nothing... : Drag & Drop any images ... make links "+" to the "box Mix"
...select 2 to 5 images on the" Workbench" and move cursors! :)
4446.3111 In reply to 4446.3109
Thanks for the info.
Interesting stuff, to be sure.
Frederick
You will find now my funny things here! :)
http://www.taron.de/forum/viewtopic.php?f=16&t=2882&start=1440
My Moi French Site
4446.3113 In reply to 4446.3110
Image to Prompt converts your pictures into optimized prompts for AI image models to create images in the style of the referenced picture.
4446.3114 In reply to 4446.3113
many thanks seems very cool! (but maybe not free! ;)
I had these
https://www.howtoleverageai.com/midjourney-prompt-
https://huggingface.co/spaces/pharmapsychotic/CLIP-Interrogator
https://promptogy.com/
https://prompthero.com/
https://lexica.art has a cool system where you can find many prompts
And my favorite free Vizcom gives me that from the example image on your your site :)
https://app.vizcom.ai
Stylized tiger with bold orange, black, and white stripes, set against lush green tropical leaves.
http://www.taron.de/forum/viewtopic.php?p=32201#p32201
EDITED: 16 May 2025 by PILOU
4446.3115
Hello Pilou,
In your AI multiverse wisdom of generators which AI image gen would you recommend to create multiple different views of the same image already generated.
thanks
Alex.
4446.3116 In reply to 4446.3115
Seems the more tricky will be made a video from one image and then take some images of this video ?
but in free you have generally only 5-6 seconds!
Kling is the more fun for this...
My Moi French Site
4446.3117 In reply to 4446.3115
And sorry i have forgotten my favorite free Vizcom!
With it you take just one image and with the function Mix (2 images minimum)
so make a dupplicate and put any % 10 to 100% to each one! (0% to each make anythings)
Absolutly miraculous!
Scroll this page and find the 2 wheels "yellow worksite vehicle" and its variations! :) ( toward bottom page)
https://moiscript.weebly.com/vizcom.html
4446.3118 In reply to 4446.3110
Create stunning videos with Veo 3 art, powered by Google's breakthrough AI video generator with native audio, 4K resolution, and realistic physics.
4446.3119 In reply to 4446.3118
seems not very free! :)
EDITED: 17 Oct 2025 by PILOU
Show messages:  1-20  …  3041-3060  3061-3080  3081-3100  3101-3119
