 1-15  …  3056-3075  3076-3095  3096-3115  3116-3119
4446.3096
Here is an Action Figure Generator that can turn photos into highly detailed, collectible-grade articulated figures, powered by GPT-4o. https://actionfiguregenerator.io/
4446.3097 In reply to 4446.3095
No no ImgBox is a free cloud for stock image! ;)
Program used is the very cool free Vizcom and it's so tricky Mix function!
You can make 100 images in 7 Minutes! So some speedy! :)
My Moi French Site
4446.3098 In reply to 4446.3097
I have a free account at Vizom AI. I love this app very much.
4446.3099 In reply to 4446.3098
Yep it´s the more versatile one!
And no limit of number of image!!!
A true gem!
My Moi French Site
4446.3100
Haha, this made my day — it's like looking at the anti-Moi universe.
Speaking of fun visuals, if anyone's into experimenting with AI-generated cartoon avatars or art, I recently found AI Cartoon Generator(https://aicartoongenerator.org) — pretty cool for turning your photos into stylized cartoon images. Worth a try if you want something artsy to contrast with all the CAD precision here!
4446.3101 In reply to 4446.3100
Yes the "opposite" as said in the thread tittle! :)
Cool i didn't known this Ai Cartoon Generator!
But seems it don't keep original model in Image to image!
Or does exist a trick ?
EDITED: 14 Apr 2025 by PILOU
Kling 2 but free version has not in free the new model of image! :(
My Moi French Site
Leonardo is incredible!
EDITED: 17 Apr 2025 by PILOU
Happy Easter Eggs! :)
My Moi French Site
40 Big Zoom Eggs : https://imgbox.com/g/t1Rp47UsBW
Vizcom Mix
My Moi French Site
Leonardo
36 big Zoom : https://imgbox.com/g/ePPEDVnkAp
My Moi French Site
OrigamiSimulator
Vizcom
My Moi French Site
4446.3108 In reply to 4446.3106
Where did all of those egg themed images originate?
Frederick
4446.3109 In reply to 4446.3108
@Fcwilt
Very easily! :)
I input this image (or similar) inside Leonardo! (will be another story for it self! ;)
Speedy Tuto
The Leonardo Section Image! (on the start online Application)
Legacy Mode (old Interface...check) / Image Guidance (check) (like Control Net on another prog)
Then load your source image above, and choose your image palette effect...here Image to Image
The Type "Control Net" image palette ...each one obviously gives a different result!
And, of course, your rendering engine (not-XL) and Element(s), if required, to achieve infinite profusion!
Here i used the cool "Isometric SFI Buildings"
And adjusting the cursor forces of all this junk... seems a little complicated... but once you've practiced a little, it works like a charm in 5 sesnonds!
In general, for a 780 x 780 size, it's 3 credits, for a 1040 x 1040 size it's 4 credits
All this over 150 automatic daily credits... and it's great, it keeps all the generations in memory!
You can run 10 generations in a row and watch their output on "Generation History"
I have used only 2 ELements ... Inferno & Baroque (Alone or both)
General tuto! :)
EDITED: 22 Apr 2025 by PILOU
For the first original image itself... free Gemini 2.5 experimental (imagen 3)
with the prompt
"a very complex colored transpararent engine Easter Eggs on Mars"
And if you want infinite variations of it...
Use the free Vizcom! with any images you want...:)
Use the Mix function...press generate any time you want...
nothing to do, no prompt, nothing... : Drag & Drop any images ... make links "+" to the "box Mix"
...select 2 to 5 images on the" Workbench" and move cursors! :)
4446.3111 In reply to 4446.3109
Thanks for the info.
Interesting stuff, to be sure.
Frederick
You will find now my funny things here! :)
http://www.taron.de/forum/viewtopic.php?f=16&t=2882&start=1440
My Moi French Site
4446.3113 In reply to 4446.3110
Image to Prompt converts your pictures into optimized prompts for AI image models to create images in the style of the referenced picture.
4446.3114 In reply to 4446.3113
many thanks seems very cool! (but maybe not free! ;)
I had these
https://www.howtoleverageai.com/midjourney-prompt-
https://huggingface.co/spaces/pharmapsychotic/CLIP-Interrogator
https://promptogy.com/
https://prompthero.com/
https://lexica.art has a cool system where you can find many prompts
And my favorite free Vizcom gives me that from the example image on your your site :)
https://app.vizcom.ai
Stylized tiger with bold orange, black, and white stripes, set against lush green tropical leaves.
http://www.taron.de/forum/viewtopic.php?p=32201#p32201
EDITED: 16 May 2025 by PILOU
4446.3115
Hello Pilou,
In your AI multiverse wisdom of generators which AI image gen would you recommend to create multiple different views of the same image already generated.
thanks
Alex.
Show messages:  1-15  …  3036-3055  3056-3075  3076-3095  3096-3115  3116-3119
