 1-9  …  230-249  250-269  270-289  290-309  310-329  …  3110-3117
PolyBrush, NeoBarok, MeshMixer...we are submerged! :)
https://neobarok.wordpress.com
Baffling! Remember the regreated Groboto in some aspects!
EDITED: 6 Mar 2018 by PILOU
Hi Pilou!
I apologize if I use this channel to ask you something specific, but I don't want to send PM.
Just out of curiosity : Are you still supporting the beta testing of R3F ?
Many interesting things has happened there.
In this period I've supported Istonia/Samardac with a huge testing phase, still not finished.
Now R3F has become even more a very good, low cost, companion for Moi.
It now has a very powerful "Take Snaphsot" command also with the chance to generate AO.
Ok, a very simple version of AO, but for quick image composition purposes in super high resolution (up to 16K) is more than enough.
If you want check the last post of this thread :
https://www.rocket3f.com/kunena/helpme/447-capture-r3f-s-viewport-in-custom-hi-res-resolution
Ciao!
4446.272 In reply to 4446.271
<< Are you still supporting the beta testing of R3F
Of course yes but alas no time to use and test it for the moment! :(
I maintain the French part of the forum when a new version is stable!
I pass all days on the forum and seen the AO adventure testing... :)
4446.273 In reply to 4446.272
@You ; "...Of course yes ..."
OK. Good to know!
I've decided in this period to help those guys (Istonia/Samardac) with my experience in image composition to make R3F even better.
Still work in progress... ;)
4446.274 In reply to 4446.224
Hi Pilou
There is also a free plugin for older versions of PhotoShop that converts to DDS
https://developer.nvidia.com/nvidia-texture-tools-adobe-photoshop
Best wishes
Keith
4446.275 In reply to 4446.274
Cool for Toshop users but I am not user of Toshop! ;)
4446.276
Designspark Mechanical has great filleting abilities, so it would be good to have a way to make it cooperate with Moi. But DM does not export to nurbs files (IGES or STEP) and so there is a problem in importing from there to Moi. Any solution to this problem?
4446.277 In reply to 4446.276
<< problem in importing from there to Moi. Any solution to this problem?
Seems you have not seen my little post about that! ;)
Take me five minutes for refind it! ;)
Ok Refound! :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6186.32
in this marvelous thread where there another a lot of true gems! :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6186.1
You have the complete solution in French here : http://moiscript.weebly.com/designspark-1.html
"Traiter les congés récalcitrant de MOI!"
give me 10 minutes for detailed it in English :)
Ok :)
Dealing with recalcitrant fillets from Moi!
Importing a Step object into DesignSpark Mechanical V1 (DMS)
Process the difficult fillets and then send the object back to MOi!
To do this, in DesignS save in the normal DSM format (MyObject.rsdoc)
Rename to MyObject.zip
Unzip: we have a.sab file in the SpaceClaim / Geometry folder of the dzipped folder
(in the arborescence of the folder file unziped)
Find the SabSatConverter.exe file address in the DSM directory of the original program
(in Windows to know the address of a file do Right Click + Shift on this file)
With these addresses one can fill the line of the "Windows Executor"!
You get something like that (one command line)
"C:\Program Files\DesignSpark\DesignSpark Mechanical 1.0\SabSatConverter.exe" -i "C:\Users\Desktop\MyObject.sab" -o "C:\Users\Desktop\MyObject.sat"
If it doesn't work we can try this!
You can add at the end of line -v with a parameter going from 4 to 24 for the headers of the different versions.
It seems -v 8 is the most operational!
Press Enter and the file MyObject.sat is created! Just import it into Moi!
That all : a bit tricky but working!
The key is run DesignSpark 1!!!
EDITED: 16 Apr 2018 by PILOU
4446.279
I think that we do need a similar feature in Moi too (I mean the 'predictive stroke' feature of Sketchbook)! I have met its need very often: drawing a free hand curve and needing than to refine it, so that may I have a very smoothly flowing curve, but without loosing its overall shape!
Maybe there is already a way of achieving such a thing in Moi... so, if anyone knows about it let drop a related note here, it would be very helpful indeed! : - )
4446.280
Hello to everyone,
A software was reference quite sometime ago on our MOI forum that allows the user to draw a spline and it produces gradients extending off of it.
It was a specialized kind of paint program.
I don't know that it was posted particularly in this thread as such.
Might anyone remember it and perhaps post an additional link to it, please.
Appreciatively,
-- MindSet
4446.281 In reply to 4446.280
Any image of what do you want exactly ?
Else as free 2D paint progs
Sumo Paint (online & local), Krita
As free vectorial prog
Gravit Designer (online & local)
Just for the fun because it's not a free prog!
It's amazing what the subdivisions'progs today can be make!
(55 videos)
An free easy Blender! ;)
https://www.bforartists.de
Free WebGL based point cloud renderer for large point clouds!
Absolutly astonished!
http://potree.org
EDITED: 18 May 2018 by PILOU
4446.285 In reply to 4446.284
Wow! Thanks Pilou!
Fluid Painter
http://david.li/paint/
and other amazing WegGl applications!
http://david.li
My Moi French Site My Gallery
4446.287 In reply to 4446.286
Oh yeah Pilou....!
I already knew that web app!
Amazing stuff!
4446.288
Interesting (blender centric) blog by Sean Kennedy here:
https://openvisualfx.com
Has a listing of free graphic software here:
https://openvisualfx.com/software/
It contains a link to a Google Doc with an even more comprehensive list here:
http://tinyurl.com/freegraphicsprograms
Hope this is useful.
-- MindSet
4446.289 In reply to 4446.288
Thanks for sharing, Mindset! Interesting indeed!
Regards,
— Metin
visualization • pixel art • illustration • 3D design — https://metinseven.com
Show messages:  1-9  …  210-229  230-249  250-269  270-289  290-309  310-329  330-349  …  3110-3117
