 1-13  …  2634-2653  2654-2673  2674-2693  2694-2713  2714-2733  …  3114-3117
From this Magicavoxel (free) image
inside the free Vizcom
After Moi3D inside in Real Time inside the free Krea "Screen to Image"
http://moi3d.com/forum/index.php?webtag=MOI&msg=4446.2665
My delirium of the day
In the free Krea function "Screen to Image" I put an another Krea!
That works like a charm! Without larsen effect!
I don't want imagine that will be made with this trick!
EDITED: 2 May 2024 by PILOU
4446.2676 In reply to 4446.2675
Cool stuff...
4446.2677
Been busy watching NHL Stanley Cup playoffs on tv, have not had much time for computer art play....
Steam Punk Rocketship via VIZCOM AI.
SOURCE was a digital illustration I painted using ArtRage in 2021 for Christmas
RESULT via VIZOM AI
4446.2678 In reply to 4446.2677
Cool results!
Vizcom is on of the more easy Free and fun Ai prog!
And free Krea in real Time with the free MagicaVoxel it's terrific!
And after inside anything you want Krea itself ...or her Free Vizcom for example :)
4446.2680
As Metin Seven mentioned in his MagicaCSG Blender thread.
A free demo of the little SDF-Modeler "MagicaCSG" is now
available (PC only and for non-commercial use only). The range
of Features is somewhat limited compared to the Patreon
version but still workable.
This Modeler is made by "Epthracy" the same guy who
made "MagicaVoxel"
You can download it here:
https://ephtracy.github.io/index.html?page=magicacsg
4446.2681 In reply to 4446.2680
More speed than me! ;)
Works fine on my more ten years old latop! :)
Denoiser
Rotate render Mode
Material render mode
EDITED: 4 May 2024 by PILOU
4446.2682 In reply to 4446.2681
was up early ;)
there are also some Examples in the .zip Package
4446.2683 In reply to 4446.2682
Download and played with it a bit. Kind of reminded me of Groboto3D but disappointed there is NO export to OBJ option.
Truly wish Darrell Anderson and Braid Art Labs would recommence development on this fine little app.
Tried Curvy3D for some time but just can not get the hang of it. And many of the functions can be done in 3D Coat which is much more user friendly then Curvy3D.
4446.2684 In reply to 4446.2683
MacigaCSG have only .PLY Export, but you can
import .PLY in Blender and also 3DCoat
For .OBJ Export you could try the free Version
of "Womp 3D" this is also a SDF-Modeler (online Tool)
as a newest Feature (still experimental) it have also
.OBJ import and even .Blend Files from Blender
and ! very unique it have a Text Tool
Here the Link
https://womp.com/index
4446.2685 In reply to 4446.2684
So very kind of you to bring to our attention all these free new digital apps that are available. Many thanks...
4446.2686 In reply to 4446.2684
MagicaCSG only has PLY 3D export format, including vertex colors.
If you import the PLY file in another editor (like Blender), don't forget to weld the vertices first. Otherwise, all polygons will be separate.
You can increase the resolution of scene objects using the "+" "-" in a circle button in the top bar!
And that works like a charm inside the free Krea!
else
EDITED: 6 May 2024 by PILOU
4446.2688 In reply to 4446.2687
I stopped using all other AI tools (except those in Photoshop) since I started using VIZCOM AI. It is simply the best for what I want to do - cars and vehicles.
Frenchy, I truly appreciate all the links and tips you post.
Kenmo
Free SDF prog inside free Vizcom
in seconds inside free MagicaCSG (local)
Then free Vizcom online...you can input any image as reference!
Even several Reference Images in the same time with % !!!
EDITED: 11 May 2024 by PILOU
Free MagicaCSG
Free Vizcom : Render, Refine 50%
prompt : organisms underwater
EDITED: 13 May 2024 by PILOU
Show messages:  1-13  …  2614-2633  2634-2653  2654-2673  2674-2693  2694-2713  2714-2733  2734-2753  …  3114-3117
