 1-5  …  2406-2425  2426-2445  2446-2465  2466-2485  2486-2505  …  3106-3119
4446.2446 In reply to 4446.2445
@Metin : Excellent info! (I was an absolute fan of MagicaVoxel! :) https://moiscript.weebly.com/magicavoxel.html
I suppose that you must make again the same when a new version of MagicaCGS becomes ?
And have you try the Womp CGS on line for compare ?
Else
From image of free Leonardo Real Time Gen inside the free VizCom
EDITED: 17 Jan 2024 by PILOU
Astonished indeed!
From a sketch by pafurijaz
Influence 100% the five free Vizcom renders!
4446.2450 In reply to 4446.2449
Thanks but the Sketch isn't mine, but one found in internet for control net, you can do the same with Moi3D or Blender LineArt if you use the export PDF and convert to jpg.
this is a conversion from Blender with IGES add-on export. but make too many edges, maybe useful in some cases but I prefer clear drawing with line art.
Outline_image
Generated images
But as you can see more edges make some issue if the sketches is well done the result is very good.
Greetings.
Night Café Pandas
16 big zoom : https://imgbox.com/g/Cv7AGEjnyu
Free MagicaVoxel FreeVizcom
Free Vizcom without prompt!!! From an image found on the Net
Free Vizcom sketch by pafurijaz
The free Vizcom is a true monster!
Free MagicaVoxel Free Vizcom
it's working fine! https://znah.net/lenia/
Using free Lenia with free Vizcom!
Ps Lenia makes also sidereal sounds!
Vizcom free permits team of 2 persons!
Show messages:  1-5  …  2386-2405  2406-2425  2426-2445  2446-2465  2466-2485  2486-2505  2506-2525  …  3106-3119
