 1-5  …  2146-2165  2166-2185  2186-2205  2206-2225  2226-2245  …  3106-3119
4446.2186 In reply to 4446.2185
Another small question. How do you get portraits in which several studies appear? Even 10 faces in different angles.
Does something have to be written in the prompt?
4446.2187 In reply to 4446.2185
I made a little tutorial 3 days ago! :)
here the 3 result with several intensities...
0.17
0.19
0.3
Absolutely no post process! Leonardo makes all!
it's that i made every day with any image! I have no time for make post process!
https://moiscript.weebly.com/leonardo-10-000-portraits.html
EDITED: 13 Aug 2023 by PILOU
4446.2188 In reply to 4446.2186
The different angle are given by the different original images taken!
I never write a prompt except the 3 ones ...
"Portrait"
"Color Portait"
or last day
"Color Portrait smiling"
for the number day 24 as you can see it 3 posts above!
one of the result! :) (i will try to refind the original)
Give me an image and see the result i obtain... with my Preraph data set!
no more than these 5 images!!! My "Preraph" data set!!!
I believe that was this one! :)
here 0.17 so maybe with a more intensity 0.19
You have never the same result if you don't use the seed number!
As you can see here some post process must be made... :)
I don't make it i just will generate an another image! :)
With this one it's not my "Preraph" as describe following on the image tutorial! ;)
Look at the prompt it's only "post appocalyptic city"
No post process ! The "Finetuned" is on the list of them given by Leonardo
4446.2190 In reply to 4446.2189
Tanks Pilou now try again :-)
4446.2191 In reply to 4446.2190
Tout va bien, super Pilou ! toutes les expériences se sont bien passées !
Je pense que j'ai compris que le truc c'est quelques photos dans le modèle, 5 suffiront. J'en avais mis 19 et elles étaient confuses.
Bien sûr, je me trompe souvent de main, mais il suffit d'en prendre plusieurs et de ne garder que les bonnes.
La seule chose qui ne fonctionne toujours pas est la post appocalyptic city, qui avec le modèle isométrique ne fonctionne pas pour moi, il fonctionne avec d'autres modèles cependant.
Merci encore Pilou !
4446.2192 In reply to 4446.2190
FAQ advises 8 to 15 images for training models!
The flowers added are just the flowers added automatically from the original image!
About my prompt "portrait" you are not obliged to input a so short one!
But as the result is sufficient for me...you can add any prompt!
(no more 75 words) will be not take in count in Leonardo!!!
II have this very rustic negative prompt! But you can add anything you want!
"nfsw signature blurry"
for the fun with the same "classic" original image above...
"color portrait similing post appocalyptic city"
with different intensities...it's endless and without efforts! :)
Playground day 235
https://moiscript.weebly.com/gaugan-365.html
Gaugan Original
Playground
100 big zoom : https://imgbox.com/g/LECjSSnUTv
Playground day 236
Gaugan original
Playground
100 big zoom : https://imgbox.com/g/uxYifcVsIS
EDITED: 15 Aug 2023 by PILOU
Leonardo Portraits day 26
10 000 portraits https://moiscript.weebly.com/leonardo-10-000-portraits.html
100 big zoom : https://imgbox.com/g/PlHnpelQaW
Leonardo Portraits day 27
100 big zoom : https://imgbox.com/g/4k8q7EyEzW
Leonardo Portraits day 28
100 big zoom : https://imgbox.com/g/zWHmifWo9u
Show messages:  1-5  …  2126-2145  2146-2165  2166-2185  2186-2205  2206-2225  2226-2245  2246-2265  …  3106-3119
