 1-9  …  2130-2149  2150-2169  2170-2189  2190-2209  2210-2229  …  3110-3119
Leonardo 100 portraits 6
big zoom : https://imgbox.com/g/18G6D8jRxy
Playground day 232
Gaugan 365 : https://moiscript.weebly.com/gaugan-365.html
Gaugan Original
100 Big zoom : https://imgbox.com/g/wteP0f9xiA
Leonardo portraits 7
100 Big Zoom : https://imgbox.com/g/12DSEL82xf
Leonardo 100 portraits 8
Big Zoom : https://imgbox.com/g/QyZEuFp1hh
Imagine
47 Big Zoom : https://imgbox.com/g/hNguFUfLck
Leonardo 100 portraits 18
Big Zoom : https://imgbox.com/g/iJ0gPvhWLQ
Leonardo portraits 19
100 big zoom : https://imgbox.com/g/8od7DMuahT
Playground day 233
Gaugan original
Playground
100 Big zoom : https://imgbox.com/g/L0A983bKQ6
4446.2179 In reply to 4446.2178
Leonardo 100 portraits - 21
100 big zoom ; https://imgbox.com/g/izFOq4HZXW
Leonardo 100 portraits - 22
10 000 portraits : https://moiscript.weebly.com/leonardo-10-000-portraits.html
100 big zoom : https://imgbox.com/g/fXZXqwPlqn
Playground day 234
Gaugan Original
Playground
100 big zoom : https://imgbox.com/g/myMV5ZHNd1
EDITED: 11 Aug 2023 by PILOU
Leonardo 100 portraits day 24
10 000 Portraits https://moiscript.weebly.com/leonardo-10-000-portraits.html
100 big Zoom : https://imgbox.com/g/oE1YwSKOEa
4446.2185 In reply to 4446.2094
Dear Pilou, I followed your instructions to try to test and train a model with Leonardo AI. I also signed up for a month so that I would have more possibilities.
However, the result I got with my pre-raphaellite girls was very disappointing compared to yours.!
I have also the impression that many of your portraits have then received post-processing afterwards (floral insertion, front and back of the ubject etc.).
I also encountered some difficulties with your nice suggestions of 25 May on this blog: with a found image on the Net prompt "post appocalyptic devastated city".
In this case I wasted dozens of tokens, because most templates simply leave everything blank.
The only one that started working was the Dreamshaper v. 7 model , and only with: Controlnet activated and only if selected on: depth or image, otherwise it produces nothing.
And also I got different designs from yours that you obviously used a different template....
I believe that your valuable blogs, and your fantastic inventions would be more appreciated if you also indicated some of the steps you encounter: type of model, slides, promt etc. I think thet a fuller step by step would be much appreciated by all your loyal followers!
Many Tanks
Fernand Leger
4446.2186 In reply to 4446.2185
Another small question. How do you get portraits in which several studies appear? Even 10 faces in different angles.
Does something have to be written in the prompt?
4446.2187 In reply to 4446.2185
I made a little tutorial 3 days ago! :)
here the 3 result with several intensities...
0.17
0.19
0.3
Absolutely no post process! Leonardo makes all!
it's that i made every day with any image! I have no time for make post process!
EDITED: 13 Aug 2023 by PILOU
4446.2188 In reply to 4446.2186
The different angle are given by the different original images taken!
I never write a prompt except the 3 ones ...
"Portrait"
"Color Portait"
or last day
"Color Portrait smiling"
for the number day 24 as you can see it 3 posts above!
one of the result! :) (i will try to refind the original)
Give me an image and see the result i obtain... with my Preraph data set!
no more than these 5 images!!! My "Preraph" data set!!!
I believe that was this one! :)
here 0.17 so maybe with a more intensity 0.19
You have never the same result if you don't use the seed number!
As you can see here some post process must be made... :)
I don't make it i just will generate an another image! :)
With this one it's not my "Preraph" as describe following on the image tutorial! ;)
Look at the prompt it's only "post appocalyptic city"
No post process ! The "Finetuned" is on the list of them given by Leonardo
Show messages:  1-9  …  2110-2129  2130-2149  2150-2169  2170-2189  2190-2209  2210-2229  2230-2249  …  3110-3119
