 1-3  …  124-143  144-163  164-183  184-203  204-223  …  3084-3094
4446.164 In reply to 4446.163
Hi Pilou!
...I really love Magica Voxel!
It's a piece of cake into the almost boring and repetitive world of CG :)
4446.165
Hi Pilou and Marco,
I love MagicaVoxel too. It's a joy to work with.
Have a nice weekend!
Regards,
— Metin
visualization • illustration • animation • 3D (print) design — https://metinseven.com
Hi Pilou.
I ask to you because you're the "SimLab" expert :)
With the "Lite" version how I can export the rendered image to 1920x1080 png without background ?
And when I click "Render to File" Simlab ask me to activate a trial license.
As you can see in this image the image resolution is not 1920x1080 and if I press the "Camera" button at bottom right the image is save with the background,
but I would like to save it without background.
Thanks for help.
4446.167
Hi Marco,
Simlab looks interesting. Does anyone know how it compares to Keyshot, in ease of use and rendering realism?
Regards,
— Metin
4446.168 In reply to 4446.167
it's more easy than Keyshot! (if possible! )
Perfect for hobbyist for the free price!
All that in 3 seconds!
EDITED: 8 Dec 2017 by PILOU
Simlab Composer Light - Lite (free)
menu Render / Exit Parameter any size till 1920 * 1080
menu Render / Environnement parameters = you choose any backgrounds !)
And you can of course change all parameter if you want more advance things! :)
4446.170 In reply to 4446.169
Ok Pilou.
But...I'm sorry...maybe I didn't understand.
What I need is to know how to, with the "Lite" version, export the rendered image to 1920x1080 png without any background (or transparent background).
Thanks.
4446.171 In reply to 4446.170
Just look attentively my image above! ;)
If you explore the Menu Background you have to choose a unic color !
So ;) Sorry it's French version but...
And for have your 1920 * 1080 you must pass by the Render Menu!
in fact I believe you can have any size that gives 2 073 600 maxi (pixel) = 1920 *1080 !
4446.172 In reply to 4446.171
Thanks Pilou for help.
A couple of hours and I'll try your suggestion.
I will let you know the results.
Ciao.
If you take the "Default background" of my first image above you will obtain a pure white Background!
white
And if you start with an empty scene you will have only object imported rendered + white background! = easy for clipping! ;)
So
PS Of course at the end after all Render parameters / Environnement, Advanced, Exit
Menu Render / To File (F5) :)
For compare versions!
http://www.simlab-soft.com/3d-products/simlab-composer-workbenches.aspx
I love it's simplicity! No headaches! And the free price for the hobbyists :)
Maybe this can interest you! :)
(you must have Flash Player installed)
2D Paint Program free Online (maxi 4095 * 4095) - Multi Languages
Maybe the more easy funny excentric toshop like ;)
SumoPaint : https://www.sumopaint.com/home/#app
Thx Patrick for the original image before playing! :)
4446.176 In reply to 4446.166
Hi Marco
see my screenshot to export in PNG without background
EDITED: 9 May 2020 by FINEMA
My method was for the JPG format! ;)
4446.178 In reply to 4446.177
you can't have a transparent background with jpeg :)
4446.179 In reply to 4446.178
Sure :)
But you can use the Magic Wand with tolerance!
JPG is better for have more colors! ;)
EDITED: 9 Dec 2017 by PILOU
4446.180 In reply to 4446.168
Thanks for the Simlab info, Pilou. I'll have a look at it.
Regards,
— Metin
4446.181 In reply to 4446.176
Hi Finema and Pilou.
Thanks for help :)
Ok.
I've made some considerations.
1) The "Lite" version is not good for me. 1920x1080 is too small. I need "print" resolution (at least A3 300 dpi 3508 pixels x 4961)
2) I'm evaluating the "Pro" version.
During the next days I will test it.
But for sure one thing that is not very good for me is that SimLab is CPU bound while some times ago I've invested my money in a powerful Gtx 1080 Ti,
and I've not invested in a multicore CPU. I have a good i7-7700K.
Actually I already have Thea Render, a blazing fast CPU+GPU rendering engine.
I need a rendering engine that should allow me to use this particular superspeed workflow for rendering of 3D concept models :
I don't want to waste my time in Retopo/UV/Texturing.
I need a rendering engine that should take the exported obj models with mid/high poly count and simply applying premade materials over them and render in one shot.
With Thea Render I can already do this thing with good results.
I want to see if the rendering quality of SimLab with that particular workflow is sufficient for me.
If so, I will accept its "slowness" of CPU bound and I will get a "Pro" license.
I will let you know.
Thanks and have a nice day.
4446.182 In reply to 4446.181
Hi Marco
What kind of rendering do you want?
Personally, I use keyshot for my renderings of objects, bottles or packaging.
I have tested Simlab Composer 8, and I find the rendering to be quite correct. But nothing replaces the professional rendering of keyshot.
That's my humble opinion.
4446.183 In reply to 4446.182
Hi Finema.
Thanks for sharing.
@You : "...What kind of rendering do you want?..."
First of all I have to say that KayShot is too much expensive for me and also it's CPU bound.
With that said...
As I said in my previous message I need to perform a particular workflow.
I don't want to waste my time in Retopo/UV/Texturing. These tasks takes too much time for doing "quick" concept rendering.
I need a render engine the that can take the "raw" obj files mid/high poly ocunt exposrted from Moi and/or 3DCoat or other packages
and applying over them premade materials that shoud give good rendering results even if the model has no UV.
All depends on this particular point : giving good rendering results with "raw" objects without any UV map.
For example the rendering engine should not create strange and bad seems or stretch too much the material applied over the objects.
I'm already using other two redner engine for this particular task :
1) Thea Render. It has the main advantage of ultrafast GPU+CPU calculation.
It also offers good rendering quality even with NO Uvmapped objects.
2) 3D-Coat : Some of you already knows how I use 3D-Coat.
I import in 3D-Coat the "raw" objs and I "voxelize" he objects using a very high poly count.
Then I apply "shaders" to the voxels and perform the rendering using the built-in internal 3D-Coat render engine.
No photorealism here and rather simple materials, but very very fast workflow. The fastest possible workflow on a PC.
OK.
With that said, now I want to see how SimLap Pro can deal with NO Uv-mapped objs and what is the rendering quality using its premade material databse.
If the results will have a good rendering quality I could even get rid of the fact that it's CPU bound, and get 1 Pro license.
I hope I made myself clear enough :)
Ciao!
Show messages:  1-3  …  104-123  124-143  144-163  164-183  184-203  204-223  224-243  …  3084-3094
