 1-20  …  121-140  141-160  161-180  181-200  201-220  …  3101-3117
Particle 9 above! :)
What a wizard of this prog!
Magica Voxel 0.99
https://ephtracy.github.io/
See here for funny previous Magica Voxel things! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=4446.41
4446.164 In reply to 4446.163
Hi Pilou!
...I really love Magica Voxel!
It's a piece of cake into the almost boring and repetitive world of CG :)
4446.165
Hi Pilou and Marco,
I love MagicaVoxel too. It's a joy to work with.
Have a nice weekend!
Regards,
— Metin
visualization • illustration • animation • 3D (print) design — https://metinseven.com
Hi Pilou.
I ask to you because you're the "SimLab" expert :)
With the "Lite" version how I can export the rendered image to 1920x1080 png without background ?
And when I click "Render to File" Simlab ask me to activate a trial license.
As you can see in this image the image resolution is not 1920x1080 and if I press the "Camera" button at bottom right the image is save with the background,
but I would like to save it without background.
Thanks for help.
4446.167
Hi Marco,
Simlab looks interesting. Does anyone know how it compares to Keyshot, in ease of use and rendering realism?
Regards,
— Metin
4446.168 In reply to 4446.167
it's more easy than Keyshot! (if possible! )
Perfect for hobbyist for the free price!
All that in 3 seconds!
EDITED: 8 Dec 2017 by PILOU
Simlab Composer Light - Lite (free)
menu Render / Exit Parameter any size till 1920 * 1080
menu Render / Environnement parameters = you choose any backgrounds !)
And you can of course change all parameter if you want more advance things! :)
4446.170 In reply to 4446.169
Ok Pilou.
But...I'm sorry...maybe I didn't understand.
What I need is to know how to, with the "Lite" version, export the rendered image to 1920x1080 png without any background (or transparent background).
Thanks.
4446.171 In reply to 4446.170
Just look attentively my image above! ;)
If you explore the Menu Background you have to choose a unic color !
So ;) Sorry it's French version but...
And for have your 1920 * 1080 you must pass by the Render Menu!
in fact I believe you can have any size that gives 2 073 600 maxi (pixel) = 1920 *1080 !
4446.172 In reply to 4446.171
Thanks Pilou for help.
A couple of hours and I'll try your suggestion.
I will let you know the results.
Ciao.
If you take the "Default background" of my first image above you will obtain a pure white Background!
white
And if you start with an empty scene you will have only object imported rendered + white background! = easy for clipping! ;)
So
PS Of course at the end after all Render parameters / Environnement, Advanced, Exit
Menu Render / To File (F5) :)
For compare versions!
http://www.simlab-soft.com/3d-products/simlab-composer-workbenches.aspx
I love it's simplicity! No headaches! And the free price for the hobbyists :)
Maybe this can interest you! :)
(you must have Flash Player installed)
2D Paint Program free Online (maxi 4095 * 4095) - Multi Languages
Maybe the more easy funny excentric toshop like ;)
SumoPaint : https://www.sumopaint.com/home/#app
Thx Patrick for the original image before playing! :)
4446.176 In reply to 4446.166
Hi Marco
see my screenshot to export in PNG without background
EDITED: 9 May 2020 by FINEMA
My method was for the JPG format! ;)
4446.178 In reply to 4446.177
you can't have a transparent background with jpeg :)
4446.179 In reply to 4446.178
Sure :)
But you can use the Magic Wand with tolerance!
JPG is better for have more colors! ;)
EDITED: 9 Dec 2017 by PILOU
4446.180 In reply to 4446.168
Thanks for the Simlab info, Pilou. I'll have a look at it.
Regards,
— Metin
Show messages:  1-20  …  101-120  121-140  141-160  161-180  181-200  201-220  221-240  …  3101-3117
