 1-13  …  1074-1093  1094-1113  1114-1133  1134-1153  1154-1173  …  3114-3119
4446.1114 In reply to 4446.1113
I know it too. ;-)
Am a long time fan of logo and turtle graphic.
Here are some Snap! alterations.
"TurtleStitch", which can be used to create patterns
for embroidery machines, also generates the code to
Embroidery machines to control. You can export your design
export also as .SVG
Here is an example:
https://www.turtlestitch.org/run#cloud:Username=elise&ProjectName=stern
There are more examples on their website, all are
directly playable.
And "Beetle Blocks" turtle graphics in 3D.
Many examples on their website.
The created model can be exported as .OBJ and .STL.
In 2D Mode, Lines could be exported as .SVG
http://www.beetleblocks.com/
an Example:
http://www.beetleblocks.com/users/Jens/projects/Hilbert%20Cube
4446.1115
Btw. like the other Tools you mention also
Big Like !
Snap : With my last one Moi textured...
Minimalist listing :)
A long way to explore!
Astonished! By the language creator himself! :)
4446.1118 In reply to 4446.1117
Indeed "Astonished " is the right word.
I have never seen this side of Snap! before.
4446.1119 In reply to 4446.1118
Your 3D Version of Beetle Blocks is some cool! (stl OBJ export ! )
4446.1121 In reply to 4446.1119
Yes, i know :)
Dont forget you could, in 2D Mode, also
save curves as .SVG.
But TurtleStitch has also something to offer. :)
https://www.youtube.com/watch?v=K6ra5ThxkrE
Size: 708.6 KB, Downloaded: 89 times, Dimensions: 785x433px
4446.1122 In reply to 4446.1121
Ah yes i have made this one! :)
Works like a charm except you must convert the SVG! (I use Affinity to PDF to Moi)
EDITED: 29 Sep 2021 by PILOU
4446.1123 In reply to 4446.1122
Nice one, Pilou !
I would also like to mention that Snap!
can also run offline.
But only within a Browser.
Here is the Link:
https://snap.berkeley.edu/offline
4446.1124 In reply to 4446.1123
yes of course but you are not sure to use the last version of Snap with the local one! ;)
In the other side maybe it's run a little more speedy when you use images! :)
else the famous one!
and the direct Snap online prog (only 2D of course)
https://snap.berkeley.edu/snap/snap.html#present:Username=jadga&ProjectName=collatz
Found on the Twetter of Jens Mönig! ;)
https://twitter.com/moenig
EDITED: 30 Sep 2021 by PILOU
Maybe not so opposited! :)
Windows, Mac, Ipad
Terrific! Cad Free with export STL low res, 3MF
EDITED: 2 Oct 2021 by PILOU
4446.1126 In reply to 4446.1125
WOW!
4446.1127 In reply to 4446.1125
The fillet system on that program is amazing.
However, I would need an overwhelming reason to use subscription based software. They all seem to hook you in, then raise prices. If you quit using, you can't edit your prior work.
That's why I ditched Adobe when they got greedy and purchased Affinity Photo / Affinity Designer.
4446.1128 In reply to 4446.1127
Yes is more for a Pro than a hobbyist !
4446.1129 In reply to 4446.1127
Same here, Ed!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
Test Snap with Moi Objects :) Any sizes or images can be used!
For one object : that is some synthetic!
EDITED: 7 Oct 2021 by PILOU
4446.1132 In reply to 4446.1131
Yep, I'm in the BETA and so far so good. It works a lot better than the Web version through a browser.
Verve is a very cool free painting prog!
EDITED: 7 Nov 2021 by PILOU
Show messages:  1-13  …  1054-1073  1074-1093  1094-1113  1114-1133  1134-1153  1154-1173  1174-1193  …  3114-3119
