 1  …  1062-1081  1082-1101  1102-1121  1122-1141  1142-1161  …  3102-3119
4446.1102 In reply to 4446.1101
Ah yes this one was very funny !
A French guy made a cool tuto presentation of it! (2003) Expression 3 - Creature House
alas some images are not more available! :(
http://web.archive.org/web/20031028183807/http://www.3dvf.com/modules/publish/Logiciels_817_1.html
Ps have you a free version for windows 10 ? Where can we download it ? i found for the moment only a mac version...
EDITED: 21 Sep 2021 by PILOU
4446.1103 In reply to 4446.1102
Yes, have the free Version "Expression 3.3" but no
Link where you could download it. Seems no more
avaible.
Alternative could be the also free Microsoft Epression Design 4.
Works on Win 10, it even have more Brushes. Very cool ones.
Here Link:
https://www.heise.de/download/product/expression-design-41150/download
Its a german Site ( because i am german ;) ) , Use the download button below.
The upper one does not work. Is named as Trial but its the full working free Version.
EDITED: 22 Sep 2021 by SUBPATH2
4446.1104 In reply to 4446.1103
Thx installed works fine except seems only in German ! :)
Now i have the name and found to download it in French ! :)
https://expression-design.fr.malavida.com/download (Expression Design 4 )
tested works fine! But seems it's not the same spirite of Creature Home (functions for that i remember) :)
EDITED: 22 Sep 2021 by PILOU
4446.1105 In reply to 4446.1104
Thats true. But find the Brushes are still fine.
4446.1106 In reply to 4446.1105
Yes funny anyway!
i must just find how draw a Brush with image or photo without close the path! :)
like above the lemon...
Maybe trivial but...maybe a background transparency...
4446.1107 In reply to 4446.1106
Look in the Help File under:
Using fills and strokes
> Define custom brush strokes
To create a brush stroke from an image, you need a bitmap image.
Open the image you want to use for the brush stroke in your document.
Select the Selection tool in the Tool palette (or press V).
Select the image, point to Stroke on the Object menu, and then click Define Image Stroke.
The Define Image Stroke dialog box opens.
Size: 246.5 KB, Downloaded: 77 times, Dimensions: 447x299px
4446.1108 In reply to 4446.1107
yes, you must set the Fill to this
Fill is the left one, Stroke the right.
Size: 16 KB, Downloaded: 81 times, Dimensions: 244x162px
4446.1109
The vector brushes also have a lot to offer.
Use one as a brush stroke (left) and make the stroke size very large (right).
An old Illustrator trick to create an interesting pattern.
Size: 65.1 KB, Downloaded: 86 times, Dimensions: 679x367px
4446.1110 In reply to 4446.1108
Yep that is that! :) THX!
So a very smart one prog simple and efficient! :) Not a gas engine! That's cool!
On my picture of the day! ;)
Moi3D + Textures from the fabulous free Online! Vervette SandBox By Taron! http://www.taron.de/Vervette/sandbox/
Render : the free SimLab Composer Lite! a "Keyshot like" but free !) (maxi 1920 *800) or if you take an old one (maxi 1920 * 1040)
https://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx
https://www.simlab-soft.com/3d-products/simlab-composer-old-download.aspx?locale=en
For the Lite : just download the normal prog (not the "trial")
else the Brush without back ground "closed" :) (in French! :)
MagicaVoxel : Animation is coming soon!
https://twitter.com/i/status/1441827172952391684
How cool is this Snap!
4446.1114 In reply to 4446.1113
I know it too. ;-)
Am a long time fan of logo and turtle graphic.
Here are some Snap! alterations.
"TurtleStitch", which can be used to create patterns
for embroidery machines, also generates the code to
Embroidery machines to control. You can export your design
export also as .SVG
Here is an example:
https://www.turtlestitch.org/run#cloud:Username=elise&ProjectName=stern
There are more examples on their website, all are
directly playable.
And "Beetle Blocks" turtle graphics in 3D.
Many examples on their website.
The created model can be exported as .OBJ and .STL.
In 2D Mode, Lines could be exported as .SVG
http://www.beetleblocks.com/
an Example:
http://www.beetleblocks.com/users/Jens/projects/Hilbert%20Cube
4446.1115
Btw. like the other Tools you mention also
Big Like !
Snap : With my last one Moi textured...
Minimalist listing :)
A long way to explore!
Astonished! By the language creator himself! :)
4446.1118 In reply to 4446.1117
Indeed "Astonished " is the right word.
I have never seen this side of Snap! before.
4446.1119 In reply to 4446.1118
Your 3D Version of Beetle Blocks is some cool! (stl OBJ export ! )
4446.1121 In reply to 4446.1119
Yes, i know :)
Dont forget you could, in 2D Mode, also
save curves as .SVG.
But TurtleStitch has also something to offer. :)
https://www.youtube.com/watch?v=K6ra5ThxkrE
Size: 708.6 KB, Downloaded: 89 times, Dimensions: 785x433px
Show messages:  1  …  1042-1061  1062-1081  1082-1101  1102-1121  1122-1141  1142-1161  1162-1181  …  3102-3119
